Fluid Changing Questions - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > Fluid Changing Questions
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineRCV Heavy Duty Axle Shafts Now Shipping at Baseline4x4.comBUMPERS by Rough Country! SOLD at ROCKRIDGE 4WD!! AWESOME
Unread 05-29-2009, 05:05 PM   #1
billabongopblue
Hey everyone,
I want to replace all the fluids in my XJ. Being new to cars overall (as this is my first car) i only know how to change the oil which i did.
I know all need to replaced, I just don't know were all the fluids are located. All i know of is oil, transmission, brake.
If you could be kind enough and list all the fluids that would need to be changed (which should be all besides oil) that would be great. Along with what they should be replaced with, as in what brand and viscosity etc.
Thank you all for the help.
billabongopblue is offline   Reply With Quote
Unread 05-29-2009, 05:29 PM   #2
jjg214
front and rear diffs, the pumpkins on the axle. you have to remove the cover to drain, then use RTV to make a new seal and let it dry, then refill up to the fill hole, 75-90 gear oil is spec. i used mobil 1 i believe. 75-140 if its a heavy duty trail/towing rig.
transfer case fluid, drain it with the drain plug, fill it with the fill plug. they are 30mm sockets on your year IIRC. put whatever you put in ur tranny in the t-case.
jjg214 is offline   Reply With Quote
Unread 05-29-2009, 06:05 PM   #3
TreddyoXJ
1997 XJ Cherokee
Radiator fluid, differential fluids, transfer case fluid, transmission fluid, and brake fluid are all fluids that you can replace. The radiator fluid is located (hence the name) in the radiator and in the motor. You can replace the radiator fluid by removing the lower radiator hose and just doing a drain and refill, or you can take it to a shop you trust that has a coolant exchanging machine and have them replace all of it.
The differential fluids are both GL5 gear lube. The differentials are the pumpkin looking center sections of your front and rear solid axle housings. Most multi-grade viscosities will work. Conventional 80W-90 will suffice unless you have a differential that is limited slip or "trac-lock" as Jeep calls it. This will requite either a synthetic or an additive specifically intended to condition the parts of the limited slip so that it will work properly. You can use a larger range viscosity (i.e. 75W-140) if you tow are put larger amounts of strain on your vehicles differentials. It's not necessary, though if you don't want to spend the extra money.
The transfer case will probably take an automatic transmission fluid such as Dextron III/Mercon. You'll need to check the tag on the transfer case to see which model number it is and what fluid it subsequently takes. The transfer case is attached to the back of the transmission and has two drive shafts coming off of it going to the front and rear differentials.
Assuming you have an AW4 automatic transmission, it will take 3 quarts of Dextron III/Mercon ATF fluid if you just drain and refill it.
Replacing brake fluid isn't really a high priority most of the time, but it can get dirty and need to be replaced. Most people just do this around the time that they do a brake job as it makes more sense. They basically need to be bleed until the new fluid that is being added starts coming out the bleeder valves.
2012 Jeep Wrangler Rubicon Unlimited in Dozer (stock)
SOLD: 1997 Jeep Cherokee Country w/D44, D30 w/ Aussie locker, Edge Trail Jammer System, 4.5" Rough Country lift, Zacatal Roof Rack, T&T front bumper, all lower body/bumpers/trim are Herculined, 31x10.5 MT Baja Claws, Warn 9.5ti. Ephesians 6:10-18
I HATE when people hijack threads. PM!
TreddyoXJ is offline   Reply With Quote
Unread 05-29-2009, 06:55 PM   #4
billabongopblue
Thank you all for the help i appreciate it.
Unread 05-29-2009, 10:20 PM   #5
conrasm
A little tip on the changing the transfer case fluid. Make sure you try to loosen the fill plug first, since that can be the harder one to get loose. That way you don't drain all the fluid and end up not getting the fill plug loose to fill it up again.
The differential fluid change is messy. Have a lot of paper towels and rags handy.
Buy yourself a grease gun and lube the steering and driveshaft fittings while you're toolin around under there. The front shaft has a fitting to grease.
Shawn
'00 TJ Sahara (RC 4" LA kit)
'06 Grand Cherokee Limited
'07 Ram 1500 quad cab
Heritage Region Jeep Alliance
conrasm is offline   Reply With Quote
Unread 05-30-2009, 12:00 AM   #6
Mean Max
Don't poke the bear
Mean Max's Avatar
This may help.
AX-15 tranny drain
AX-15 tranny fill plug
NP 231J transfer case drain & fill plugs.
And here's some differential gear oil change info.
http://www.jeepforum.com/forum/f12/basic-diff-lube-maintenance-728231/
Max
Click here to see all of my different albums on Photobucket.
Choose any album to see all of my pics!
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline   Reply With Quote
Unread 05-30-2009, 05:14 AM   #7
nujeepguy
1997 XJ Cherokee
my 231 transfer case takes a 9 or 10 mm (can't exactly recall)allen wrench it isn't 30mm hex. so take a look on yours to be prepared.
nujeepguy is offline   Reply With Quote
Unread 05-30-2009, 08:00 AM   #8
Mean Max
Don't poke the bear
Mean Max's Avatar
True enough, some NP231's (especially newer than my '91 YJ) have 10mm, and some others have 17MM, allen head drain & fill plugs.
I should probably update & include that info on the pic.
Thanks!
Max
