Floor mount dimmer mod - JeepForum.com
post #1 of 14 Old 10-21-2012, 09:28 AM Thread Starter
zimsy
1993 XJ Cherokee
My multi function switch is broken and I cannot piece it back together. I plan on installing a floor mounted dimmer switch. Here is my problem, I have 5 wires and only 3 prongs on the floor switch. 2 purple/white, 1 pink/green, 1 red orange, 1 heavier gauge black/tan. I believe the black/tan is the ground. The 2 purple/white wires were connected together. Stupid Chilton's manual didn't have the wires the same color. Can someone tell me how to go about this and if I have the wrong switch?
zimsy is offline
post #2 of 14 Old 10-21-2012, 05:17 PM
buildin1XJ
Just repair your multi function switch and keep your XJ complete. KISS keep it simple stupid
buildin1XJ is offline
post #3 of 14 Old 10-21-2012, 05:35 PM Thread Starter
zimsy
1993 XJ Cherokee
That switch is like $100 though!
zimsy is offline
post #4 of 14 Old 10-21-2012, 06:02 PM
buildin1XJ
Be a junk yard man,nothing wrong with that,at my local pull a part might cost 10$
post #5 of 14 Old 10-21-2012, 11:16 PM
sAe23
1995 XJ Cherokee
Best as I can read the FSM for my 95, the black/tan is ground, the red/orange is high beam and the violet/white is low beam.
I'm not sure what pink/green is, but something needs to feed the dashboard high beam lamp
I would also suggest getting the proper part, or at least your own FSM for your year so you can be SURE of the wiring
sAe23 is offline
post #6 of 14 Old 10-21-2012, 11:26 PM
sAe23
1995 XJ Cherokee
Found a reference that shows the pink/green feeds POWER TO the "beam select switch" and the dashboard lamp it lit by some other wire...
Would still suggest using the correct part.
sAe23 is offline
post #7 of 14 Old 10-22-2012, 07:37 AM Thread Starter
zimsy
1993 XJ Cherokee
Thanks guys. Gonna go swap the part tomorrow.
zimsy is offline
post #8 of 14 Old 10-22-2012, 09:09 AM
RIjon
Man I miss floor high beam switches. Seemed like a no brainer as your left foot is almost always doing nothing. Never really understood why they stopped installing them. Probably due to constant corrosion.
Switch panels for our jeeps
2008 Toyota Tundra RCSB Supercharged
1998 Cherokee Classic ..... work in progress
RIjon is offline
post #9 of 14 Old 10-22-2012, 10:00 AM Thread Starter
zimsy
1993 XJ Cherokee
Oh man this is so funny! So I started lengthening the wire to run to te floor switch and with nothing hooked up to it yet, I connected the negative battery cable and pulled the knob out to see if I would get headlights. What happens next amazes me....the warning buzzer came on every time I pulled the knob out!!!! It had never worked before and now it is with the 5 wires just hanging there. This is crazy!?!!??? Can anyone explain how the warning buzzer is wired in to the lights/door ajar?
zimsy is offline
post #10 of 14 Old 10-22-2012, 02:43 PM
sAe23
1995 XJ Cherokee
Best as I can read the schematic, when the headlight switch is in either Park or ON, a circuit between the left front door switch and the chime module is connected.
The wire between the door switch and headlight switch is lite blue, and the wire between the headlight switch and chime module is pink/light blue (Same color as the "key in ignition" circuit).
So, IF the drivers door is open AND either the key is in the ignition OR the lights are on, the chime will sound.
(I assume no responsibility for any misinterpretation. You should get a copy of the FSM...)
sAe23 is offline
post #11 of 14 Old 10-22-2012, 03:38 PM
buildin1XJ
I do like the floor mounted switch idea however the multifunction switch controls more than head lights and when those functions go out you will be replacing it then.I see where your trying to tap into wires and not having the best of luck yet.I still suggest you fix it right now and avoid later problems.I don't mean to come across as rude but I think you could possibly be causing other problems.
post #12 of 14 Old 10-23-2012, 02:39 AM Thread Starter
zimsy
1993 XJ Cherokee
Yea, I'm just gonna pony up the cash to buy the switch. Hopefully I can install it properly.
zimsy is offline
post #13 of 14 Old 10-24-2012, 05:39 AM
sAe23
1995 XJ Cherokee
Installing the part should be a breeze.
All you need is a schem... er... nevermind.
(Just kidding!)
sAe23 is offline
post #14 of 14 Old 11-02-2012, 04:11 PM Thread Starter
zimsy
1993 XJ Cherokee
Super easy install...still haven't purchased the multi switch but did actually wire up the floor switch. The violet/white wires go on either the left or right terminal on the switch, the red/orange wire goes to the opposite terminal, the black/tan ground wire goes to the middle terminal. Step on the switch and the high beams light up. Simple. I just left out the pink/green wire. Might install another toggle or flip style switch for the dash light. Voila!
zimsy is offline
dimmer switch , headlight switch install , wiring diagram
