Flooded: Do i need any fluid changes? - JeepForum.com
post #1 of 11 Old 09-21-2009, 05:08 PM Thread Starter
mbgp
1995 XJ Cherokee
So my jeep was submerged in some brown river water today in the school parkling lot after it flooded. the water was right under my bottom door seal, no water got in but it obviously covered the whole diff and my exhaust was submerged for about 30 minutes. the jeep still runs tho. i was thinking to just change the diff fluid (rear. its a 2wd) and run a can a seafoam thought the tank? its a 2001 with the 4.0 and a d35 rear
mbgp is offline
post #2 of 11 Old 09-21-2009, 05:18 PM
justanotherjpr
Transmission fluid and engine oil look good?
So do you actually hear your thoughts in your head or is it just sort of a dull roar before you smash your face into your keyboard and just submit whatever dumb **** ended up on the page?
justanotherjpr is offline
post #3 of 11 Old 09-21-2009, 05:20 PM Thread Starter
mbgp
1995 XJ Cherokee
i gotta check, its still pouring over here! oil should be brown and trans fluid??/? im a newb
mbgp is offline
post #4 of 11 Old 09-21-2009, 05:22 PM
justanotherjpr
Trans fluid should be red and smell sweet. I would not drive or even start the Jeep until you verify both fluids are good or change them both with their respective filters.
post #5 of 11 Old 09-21-2009, 05:25 PM
Jeep89JV
Sweet as cat piss , x2 on this though.
If you don't stand behind our troops, feel free to stand in front of them.
My Build Thread:
New Mexico Driving Rules...
  • As a general rule, the vehicle most in need of a significant amount of bodywork (for which the driver is most likely uninsured) always has the right of way.
  • Never use directional signals when changing lanes. They only serve to give away your next move, causing most NM drivers to speed up and not let you in. In fact, use of directional signals within most large NM city limits is actual illegal.
  • NM law states that at least 50% of all paved surfaces within the state must be under construction at any one time. In all construction zones, at least half of the available lanes must be closed, regardless of whether any actual construction is be accomplished or not. Construction signs shall be regularly repositioned in order to warn drivers about upcoming lane closures immediately after they pass the last exit before traffic backups.
  • Driving through constructions zones with upcoming lane closures is a popular game in NM. Itís called the "speed up and pass as many cars as you can, then see how close to the lane closure you can squeeze back into traffic before hitting any of the orange construction barrels" game.
Jeep89JV is offline
post #6 of 11 Old 09-21-2009, 05:29 PM
stoneytj
x3 yep just did the same thing on mine.
RIP Keith Andrus 1985-2010 you will be missed buddy
build thread
stoneytj is offline
post #7 of 11 Old 09-21-2009, 05:32 PM Thread Starter
mbgp
1995 XJ Cherokee
so i just checked both fluids and they both are fine. anything else i should worry about? my brakes were creaking loudly for a few minutes after i got it out of the water.
mbgp is offline
post #8 of 11 Old 09-21-2009, 07:25 PM
Holder350
1995 XJ Cherokee
If the rear vent was where it was suppose to be in the frame rail, you didnt get anything in the axle...as long as it wasnt hot
95' XJ Country - Stock Skids - D30/D35 Limited Slip - 3" Lift - 31x10.50R15 - 4.0 HO - AX15 - NP231
98' XJ Classic - D30/C8.25 - 4.5" RC Lift - 33x12.50R15 - 4.0 HO - AW4 - NP231
Originally Posted by Azzy View Post
You can tell the character of a person in how they treat someone who can do nothing for them.
Holder350 is offline
post #9 of 11 Old 10-12-2009, 04:43 PM
RenegadEpl
Same thing happened to me except i was stuck in water for over an hour with the engine running and after i puled it out i had water in the transmission ..... should i worry about water in different places ?? what should i look for and what should i change ?
RenegadEpl is offline
post #10 of 11 Old 10-12-2009, 05:21 PM
dacotua
1992 XJ Cherokee
Check your rear differential. I know it has a vent tube, but many of the rear ends have a rubber push in plug for the rear differential fill hole. Water can get around that stupid plug... TRUST ME I KNOW FOR A FACT.
dacotua is offline
post #11 of 11 Old 10-13-2009, 04:39 PM
RenegadEpl
i might as well just change all the fluids ... im not sure what to do about the water in the transmission . im not sure how to get it all out . and should i just change my every fluid ? and any gaskets while im at it ?
flooded the XJ XJ352 XJ Cherokee Technical Forum 18 06-22-2009 11:57 PM
flooded 4.0 liter inline 6 civiccx95 XJ Cherokee Technical Forum 10 10-29-2008 01:38 PM
Interior flooded with Gasoline girlcrazy_4 XJ Cherokee Technical Forum 14 09-20-2006 12:09 PM
flooded jeep89 XJ Cherokee Technical Forum 8 09-08-2004 08:48 PM
Help!! How can I start a flooded jeep?? VaTech XJ XJ Cherokee Technical Forum 4 10-24-2002 10:23 PM
