flat tow bar hook up? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > flat tow bar hook up?
DISCOUNT - Chromoly Front Axle Shaft Kits, 87-95 YJ's, 97-Rough Country Deals at JeepHut.comIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 04-08-2011, 05:13 PM   #1
YJames90
aka Jamesx2
YJames90's Avatar
I am picking up a 90 XJ tomorrow morning and need a quick way to temporally hook up my tow bar to the front of the XJ.
Are there spots where I can secure the tow bar to without drilling and bolting on the mounts?
Originally Posted by timatoe View Post
SOA is completely out of you're league at this point.
Originally Posted by JeeperDon View Post
Some Jeepers can do some of the mods some of the time, but not all Jeepers can do all the mods all the time. :cheers2:
My 2.5 to 4.3 swap thread
http://www.jeepforum.com/forum/f12/4...begun-1237704/
YJames90 is online now   Reply With Quote
Unread 04-08-2011, 06:22 PM   #2
DoctorPhate
XJ Cherokee
You can hook up the tow bar to the plastic grill and it'll be about as secure as hooking it up to the bumper/"frame"
Just remember not to move at all....
You need to reinforce the unibody before you put any stress on it. Its not a frame.
DoctorPhate is offline   Reply With Quote
Unread 04-08-2011, 07:30 PM   #3
YJames90
aka Jamesx2
YJames90's Avatar
uhhhh, OK .So, where IS a good mounting point...Anyone?
Unread 04-08-2011, 07:53 PM   #4
mnoeltne
There is none on a stock XJ. Even if you would drill it. Too flimsy.
I had a custom winch type bumper made, but with no winch, instead it has hookups for my Roadmaster towbar to hook on. That has heavy metal extensions running back along the frame beside the motor. They must go back at least 18" and bolt up in multiple places.
The whole front is just basically sheet metal and will not hold up to pulling even a block or so. You need the tie-ins to the unibody frame area where front hitches, and winch bumpers bolt to.
Mark N
2001 Sport - almost stock
mnoeltne is offline   Reply With Quote
Unread 04-08-2011, 08:17 PM   #5
YJames90
aka Jamesx2
YJames90's Avatar
Thanks RX
Unread 04-09-2011, 07:06 AM   #6
YJames90
aka Jamesx2
YJames90's Avatar
Deceided to trailer it
