Flashing engine light - JeepForum.com
post #1 of 15 Old 09-11-2012, 07:16 PM Thread Starter
SkeeterJeep
So 2 weeks ago my engine light started flashing, took it to the garadge to get fixed, they said it was a misfire.. But the Manuel said exactly that its a Cadillac converter problem...tried telling that to him but its wrong obv (sheesh) anyway, today it started doing it again.. truck shakes like its in an earthquaks as soon as i get just under 30.... any ideas?
SkeeterJeep is offline
post #2 of 15 Old 09-12-2012, 05:24 AM
tjwalker
It's the crank sensor!
tjwalker's Avatar
Is this on your WJ? If so, you are in the wrong forum. These forums are model specific.
In general though, a flashing check engine light indicates a SERIOUS misfire, which if ignored, will destroy your catalytic converter.
You need to resolve this ASAP. There are a whole host of causes of misfires.
99 Cherokee, 4.0 AW4, NP242
Past Jeeps: 49 Willys, 81 Scrambler, 88 Comanche
Without "data", all you have is an opinion!
tjwalker is offline
post #3 of 15 Old 09-12-2012, 05:53 AM
JerpXJ
This happened to me a few months ago, turned out to be a dead injector.
JerpXJ is offline
post #4 of 15 Old 09-12-2012, 07:46 AM
Paradise XJ
1988 MJ Comanche
Like tjwalker said, a flashing light is there to get your attention...as in "Hey, stop driving and fix this problem".
This is a basic rule for ALL OBDII vehicles, even Cadillacs!!?
1990 XJ Laredo - White & Chrome
1988 MJ Pioneer - Metallic Green and Black
Paradise XJ is offline
post #5 of 15 Old 09-12-2012, 08:04 AM
GetLifted
It converts into a Cadillac?? lol thats funny.
CHECK YOUR GAP. Champion set at .035. Dont skip this part. Report back on conditions of plugs and while your in there do a compression test.
GetLifted is offline
post #6 of 15 Old 09-12-2012, 10:11 AM
pumpkinXJ
Being a tech, I can see where he told you that you were wrong. That's just about every techs petpeve is when customers bring there car in self diagnosed.
When the engine light is flashing its most of the time due to miss fires that can cause damage to the catalyst. Either pull codes and put them on here so we can help you determine what's causing the miss fires or take it to the shop and just tell them its running rough and the cel is flashing. Then see what they tell you.
current 99xj (5.5 on 36s)
past 98 xj (4.5 on 33s)sold 95 zj (stocker)sold
Originally Posted by -Deepskyy- View Post
If it ever happens to me, I'll just put the clutch down to the floor, and start revving the YJ up to about 3500 and then yell out "I'M SORRY I CAN'T HEAR YOU OVER THE SOUND OF AWESOME COMING FROM MY JEEP!"
pumpkinXJ is offline
post #7 of 15 Old 09-12-2012, 02:44 PM Thread Starter
SkeeterJeep
No its on my XJ (i know the difference in the forums), and now he is saying its prob a bad injector. There are no stores around within 40 miles that can pull codes, i live in the middle of no where.
post #8 of 15 Old 09-12-2012, 02:46 PM
pumpkinXJ
Did he pull codes? Ask him what codes he got.
post #9 of 15 Old 09-12-2012, 03:15 PM Thread Starter
SkeeterJeep
He does not have the machine needed to pull the codes. This is an old town and he is the closest garage in 70 miles....I miss virginia.... lol
post #10 of 15 Old 09-12-2012, 03:22 PM
pumpkinXJ
Take the drive to a shop that will be able to pull codes and properly diag the jeep. Otherwise be prepared to spend a lot of money throwing parts at a problem, that you arnt sure what's causing it.
post #11 of 15 Old 09-12-2012, 05:38 PM
tjwalker
tjwalker's Avatar
You still haven't told us what YEAR your XJ is.
This information is critical to getting proper responses.
tjwalker is offline
post #12 of 15 Old 09-12-2012, 09:22 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
1) Pull your own codes. Buy whatever is required to do so. Your Jeep is trying to tell you what is wrong.
2) Get a better mechanic. Sounds like your mechanic can't find his backside, with both hands trying.
CJ7-Tim is offline
post #13 of 15 Old 09-13-2012, 12:28 AM
GetLifted
Turn the key forward and back 3 times leaving it in the on position. Count the blinks. The codes come in 2 digits (12-battery disconnected last 50 starts, 43-coil driver, 55- codes done)
Lol i bet those are your codes. And i bet youll pull code p1391 with a OBD2 scanner. Infact your online. Order a dang OBD2 scanner for like 40$ on amazon!
post #14 of 15 Old 09-14-2012, 06:23 PM Thread Starter
SkeeterJeep
sorry it is a 2000. and it ended up being both injectors. one was dead and the other was misfiring a lot..
post #15 of 15 Old 09-16-2012, 02:57 PM
JerpXJ
I had the same issue in my 2000 like I said previously. Replacements arnt really all that much either.
JerpXJ is offline
Flashing Check Engine Light, No Code Bmoore89 XJ Cherokee Technical Forum 2 06-26-2011 11:26 PM
Chk Engine Light Flashing, Shifing Weird cja1987 XJ Cherokee Technical Forum 18 07-31-2010 09:12 PM
Flashing check engine light paule01 XJ Cherokee Technical Forum 4 04-18-2010 09:31 PM
Engine Light on Forever, flashing, what the heck. dirt machine XJ Cherokee Technical Forum 18 01-18-2008 05:09 AM
Flashing check engine light thegiant80 XJ Cherokee Technical Forum 7 01-25-2007 05:03 PM
