Fitting KJ Liberty rear disc brakes to an XJ Cherokee 8.25 axle
#16 | |
Do they really have enough breaking power? those rotors look kinda small, I'm just worried about overheating when coming down a Long, Steep, canyon road. I've been wanting to do something like this for a really long time.
#17 |
for the breaking power, disc are much better than drum, and if your worried about ventilation, find some slotted, cross drilled rotors. I really want to do this conversion. now time to find a kj in a junkyard
#18 | |
I think you'll be pleased. |
#19 |
Disk is far superior in all aspects to Drums (power/heat dissipation/function), and all around is way more efficient.
My truck stops ok, but I have brand new EVERYTHING in my braking system, so it should. I still want to swap to Disks... safer, better for towing, etc. Disks FTW
2000 Jeep Cherokee Classic 1992 M101 CDN2 1/4 Ton Off-road Trailer. 90% Daily Driver 100% Fun! ____=__= l l ,[_____], l---- L -[]lllllll[]- ()_) ()_)--o-)_) |
#20 |
the rear disks are solid if I'm not mistaken, not sure it possible to have drilled, etc, they don't ever overheat from what can tell. the stopping power is better and more consistent in my opinion. If you install it completely including a prop valve you basically have ZJ brakes in a vehicle that weights what 500lbs less?
#21 |
you can always find slotted or drilled rotors, ebay is great for that. I went with just slotted for my fronts after I bagged myself a trailor hitch. but my brakes need a lot of work
#22 |
ya knows what bugs me about this thread.. there is no final pic of the full assembly
#23 |
Is the parts list on the front page the COMPLETE parts list other than brake fluids etc which were mentioned later? I am going to call a few local JYs to see if I can get the swap parts together. My rear drums are making noise and I would rather have rear discs anyway. Thanks!
Metzroth
2000 XJ Classic - 33" GY Duratracs, 15x10 Cragar V5s, Crown HD springs, Clayton adjustable shackles, OME Nitrocharger Sport Long Travel Shocks, JKS Discos, extended brake lines, 2" poly spacers in front with V8 ZJ springs, Powerslot Rotors, Hawk HPS Pads, Hella E-Code headlight housings, Narva 100/130 Bulbs, Olympic Top Hat Rack, etc. |
#24 |
Nice write up. Its good to know that there is another option (without grinding out the backing plate no less) besides a ZJ disc conversion.
#25 |
KJ cables
Does anyone know where to get the KJ cables for cheap the dealer near my house wants $53. Thanks.
#26 |
this may sound odd but why use an angle grinder with a sanding disc? the surface still looked a little rough.
why not just put it in second gear and progressively wet sand it by hand or with a sanding block? too dangerous, maybe? not saying it isn't a great idea. i know my next brake job will be a lot cheaper and easier.
'87 XJ Pioneer with 32" KM2s, etc. |
#27 | |
#28 |
I keep seeing this comment and it's true, I really need to re-visit this project and snap a few completed pics' with the rotor and caliper in place. The only problem is it doesn't look nearly as impresive now it has a good coating of baked on gloop!
#29 |
i have rear disc brakes from a zj and i was just wondering if i need to do anything to the master cylinder
dose the disc brakes take more pressure? |
#30 | |
The discs can handle more pressure than the drums and some guys modify their stock proportioning value by removing the spring and seal. I am running the stock prop valve and have had no issues. |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
