a few greenhorn questions... - JeepForum.com
post #1 of 6 Old 11-20-2005, 11:42 AM Thread Starter
94lifted
howdy, first post here
just picked up my first jeep couple weeks ago!
1993 Cherokee Country
4.0 HO
3.5 skyjacker
31" open country
2 1/2" header back exhuast
i searched around for answers but to no avail, couple small things wrong with it i was hoping to get some help with!
autozone and shucks insist it has no pcv valve?! yet the thing that exactly resembles a pcv valve is leaking slightly... what pcv valve can i pick up to replace it with?
Temp guage is totally inaccurate, can i fix this?
slight rythmic grinding noise coming from the rear? yet all wheel bearings seem fine (don't shake at all) could this be the rear diff?
and a ******* question but all fourwheel drives are not the same. what are the rules for shifting into 4x4? (like always in neutral or below a certain speed etc etc)
pre-thanks! theres alot of knowledgable ppl on here! i'll get some pics up after i wash the poor thing
94lifted is offline
post #2 of 6 Old 11-20-2005, 11:51 AM Thread Starter
94lifted
pics
coupla pics from my camera phone... sorry bout the qualitee and sorry i don't have more posts lol
In Town
at timberline
94lifted is offline
post #3 of 6 Old 11-21-2005, 06:24 AM Thread Starter
94lifted
bump for some wisdom
94lifted is offline
post #4 of 6 Old 11-21-2005, 06:51 AM
98SportDrvr
98SportDrvr's Avatar
hmm lets see here young jeeper apprentice. Ignor what altozone and the other store say. there are two pcv valves. Both are on top of you valve cover. If you are leakin from these theres two solutions. pull said pcv valves and clean them out. the other is to walk into a descent autoparts store with the valve(take it off in the parkinglot) walk past the idot counter and walk till you find the pcv valves. they have them but their too dumb to know. That or hit up a local junkyard and grab one wont cost ya but 50 cents max or free at junkyard. make sure its not clogged and there ya go.
THe temp gauge is off how? Do you know for a fact its running hot or cold? THese things normally run around 195-210 degree's stock. If you know for a fact its inaccurate try checking the sending unit, might just be bad or loose connections. That or just go get some aftermarket gauge and mount it up.
Your rear end noise IS your diff. Is it a grinding or wining noise? if its a wining noise your pinion bearings are worn and need fixing. It happens, heck mine wine since i rebuilt my diff. Can't explain it. one day ill fix it.... If its a grinding noise, then well it could be worn, chiped, cracked, gears. Could any of the gears in ur diff. best way to check is to pop the diff and look for metal shavings and spin the axle looking for bad wears or chunks missing.
Last but not least the 4x4 engagement. its really easy. to go from 2wd to 4hi the shifting is on the fly, try and do it at low speeds just to be on the safe side. to get into neutral is just another shift away. To put it in 4lo put it in neutral, shift, put in drive and go. rolling, aka barely moving makes this easy. thats the way to do it, if thats ur x-fer case ya got. if remember right ya got the 231 which is settup 2wd, 4hi,Neutral then 4lo. If not tell us and can we can tell ya how to shift her.
used to have my project jeep.... had to sell her and now i just dream of the future.
98SportDrvr is offline
post #5 of 6 Old 11-21-2005, 10:20 AM
law.74
I don't believe they are "valves", but grommets rather. The valve cover should vent freely to the intake or for those who don't care about EPA stuff vent them straight to the engine bay. HOWEVER... Some people replace the old grommets with GM grommets and PCV valves. You may have a PO non-OEM fix.
law.74 is offline
post #6 of 6 Old 11-21-2005, 11:03 AM
98SportDrvr
yes they are just vents. i was just calling them valves cause thats what i always called em. some pcv's are actually valves though, they open and shut with air pressure. the ones on the xj are just open with no valve.
Radiator Questions + Lift Questions billabongopblue XJ Cherokee Technical Forum 3 08-10-2009 01:25 PM
Xj Lift questions 4.5 lift PLus blocks questions.. tmarks15611 XJ Cherokee Technical Forum 13 04-17-2008 07:57 AM
Two questions... XJ_jeepin_06 XJ Cherokee Technical Forum 3 11-30-2006 09:08 PM
bad t/c got questions beav XJ Cherokee Technical Forum 1 11-29-2006 09:33 AM
SYE and CV Drive shaft Questions (and a questions for the Colorado guys) jaardesign XJ Cherokee Technical Forum 4 08-09-2004 11:14 AM
