Few electrical issues, need help before inspection - JeepForum.com
post #1 of 7 Old 06-11-2013, 06:30 PM Thread Starter
79chiefs
1988 XJ Cherokee
1-Wipers only work on full speed
2-No turn signals-believe it is the relay and gonna go change it with a new; post your thoughts on this
3-No horn
4-not needed for inspection but also could use help---no dash lights at all
5- temp gauge does not work, how can i test it; cannot afford to get a new sensor right now just for it to not be the problem.
PLEASE HELP
88 Jeep Cherokee 4.0 Auto 4x4
99WJ Laredo I6-A 2wd
88XJ-Building on a budget.
95 E34 540i-DD
79chiefs is offline
post #2 of 7 Old 06-11-2013, 06:51 PM Thread Starter
79chiefs
1988 XJ Cherokee
Changing the relays did not help, still no turn signals, and now hazards flash weird.
NO fuses blown.
95 E34 540i-DD
79chiefs is offline
post #3 of 7 Old 06-12-2013, 11:13 AM Thread Starter
79chiefs
1988 XJ Cherokee
Bump???
95 E34 540i-DD
79chiefs is offline
post #4 of 7 Old 06-12-2013, 12:07 PM Thread Starter
79chiefs
1988 XJ Cherokee
Took all fuses back out and put in at random, signals now work.
Now it is missing like crazy.
I NEED the horn for inspection.
95 E34 540i-DD
79chiefs is offline
post #5 of 7 Old 06-12-2013, 07:57 PM Thread Starter
79chiefs
1988 XJ Cherokee
Found the horn relay, i never thought it would be that hard, i read so many threads that none had ever found it, but i did, and it is bad, jumped the pins till it sounded the horn.
run out of gas, so that is the missing issue, i think my gas was stolen because i put 6 gallons in it, and it has just sat for 2 weeks while i get the paperwork done on it.
95 E34 540i-DD
79chiefs is offline
post #6 of 7 Old 06-12-2013, 07:58 PM Thread Starter
79chiefs
1988 XJ Cherokee
So 2;3;5 are solved
5- grounded out the gauge and it worked so i bought a sensor.
95 E34 540i-DD
79chiefs is offline
post #7 of 7 Old 06-13-2013, 10:27 AM Thread Starter
79chiefs
1988 XJ Cherokee
Forgot most important part
STILL NO BRAKES
I have bled many times, gravity, force bleed.
95 E34 540i-DD
79chiefs is offline
