Fender Trimming - Can I Still Use Original Fender Flare Once Done? - JeepForum.com
post #1 of 6 Old 12-09-2010, 02:20 AM Thread Starter
casbboy
I have a 3.5" lift on my XJ and took the chance of fitting 32"x11.5" tires. They look great, they work great, but they definitely rub the fender a bit.
So I'm guessing a need just a bit of trimming. So my question is, when only a little is cut off, can I still use the original Fender Flares or is it time to go shopping? (for something like bushwacker).
I've attached a link to a photo of my XJ with the new tires/wheels.
http://i1093.photobucket.com/albums/...y/IMG_0523.jpg
Thanks
Ryan
casbboy is offline
post #2 of 6 Old 12-09-2010, 05:27 AM
1990JEEPXJ
1990JEEPXJ's Avatar
1990 XJ Cherokee
you can trim and then drill new holes to mount the stock flares up a little higher.
1990JEEPXJ is offline
post #3 of 6 Old 12-09-2010, 05:27 AM
mosh-n-roll
2009 JK Wrangler
I read a pretty good write up on exactly what you're looking to do. It is possible to use the factory flares after trimming the fenders. I don't remember where I saw the write up, but I'll try and find it for ya
mosh-n-roll is offline
post #4 of 6 Old 12-09-2010, 05:31 AM
mosh-n-roll
2009 JK Wrangler
Didn't have any luck finding the write up I saw before, but I found another. Hopefully it'll help you out.
Front Fender Trim Write Up (Retaining the stock flare) - NAXJA Forums -::- North American XJ Association
post #5 of 6 Old 12-09-2010, 06:58 AM
Kevin108
EricsXJ has done it so PM him or maybe try searching through his threads. This was the only pic I could find.
My build thread has pics again. http://www.jeepforum.com/forum/f177/kevin108s-2000-xj-build-867428/
Kevin108 is offline
post #6 of 6 Old 12-09-2010, 10:58 AM Thread Starter
casbboy
Awesome. Sort of relieved. While I do like the Bushwackers a lot, I have nothing against the fender flares I have now.
Cheers!
Ryan
casbboy is offline
Fender Trimming xjsport96 XJ/MJ Cherokee Non-Technical Forum 9 05-27-2009 09:02 AM
Fender Trimming JeepXJ1991 XJ Cherokee Technical Forum 20 02-14-2009 06:58 PM
Fender Flare/ trimming 99cherokeexj XJ Cherokee Technical Forum 4 09-08-2007 02:23 PM
Fender trimming 89Cherokee4x4 XJ Cherokee Technical Forum 10 09-19-2006 09:24 PM
Fender Trimming 4x4rob XJ Cherokee Technical Forum 8 06-01-2003 08:25 PM
