Quantcast Fender trimming - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > Fender trimming
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineFREE shipping on Rugged Ridge Soft tops @thejeephut.comGR8TOPS Introduces the Exogate HD Tire Carrier
Old 01-25-2009, 02:10 PM   #1
89XJBEAST
Fender trimming
What is the best way to trim fenders so that it actually looks neat?
89XJBEAST is offline   Reply With Quote
Old 01-25-2009, 02:23 PM   #2
xjfever
forum supporter
xjfever's Avatar
1995 XJ Cherokee
With a jigsaw, qnd a 24 tooth per inch metal cutting blade. just cut off the flat part where the bolt holes are in the front. and cut and fold the rear to match. http://www.jeepforum.com/forum/f11/write-up-cutting-folding-rear-fenders-632436/
  2. '99 WJ limited, 4.7L, 3" IRO lift. Bilstein shocks, JK rubicon wheels, 255/70/17's, carolina driveshaft, IRO adjustable control arms, IRO adjustable A-arm
xjfever is offline   Reply With Quote
Old 01-25-2009, 02:24 PM   #3
Bobandbeans
i used an angle grinder.. turned out good. just take your time.
2000 xj Lifted, Locked
1996 xj my dd
"I swear to God, I'll pistol whip the next guy who says shenaningans!"
Bobandbeans is offline   Reply With Quote
Old 01-25-2009, 02:44 PM   #4
89XJBEAST
I saw a lot of the info on the rear fenders what about the fronts should i attempt to cut and fold or just trim them higher?
Old 01-25-2009, 07:41 PM   #5
xjfever
forum supporter
xjfever's Avatar
1995 XJ Cherokee
You can just cut the fronts off. I would do the rear first then cut the front to match, but you can cut the front higher. There is a lip inside the fenderwell on the front, that you will see when you remove the inner fenders. If you are gonna stuff your tires any you should cut and fold this lip.
Old 01-26-2009, 06:53 PM   #6
Bowhunter46563
4" Angle and a Dremel, works pretty well.
01 XJ/4" lift/33" DC Muds/Sidebiter Wheels/Surco/ Hi-lift/Pilot lights/Bad Apple Fab diff gaurds/Front and rear receiver hitches/Rusty's LCA's/ Magnaflow/Rubi HD Track bar and Brace/Big Daddy tie rod/TB Spacer/Ractive air intake/ Jet Stage 1/Pioneeer & Fusion Sound/AJ's Super rails/Warn Skid /BW Flat Flares/Bedlined Rockers and Quarters
Bowhunter46563 is offline   Reply With Quote
Old 01-26-2009, 07:43 PM   #7
bmyohn
Youngin'
bmyohn's Avatar
3" air tool grinder. made quick work of it. trim both front fenders, and cut and folded the rear in less than an hour
2001 Dodge Ram 2500 SLT 4x4
5.9L Cummins Turbo Diesel
"The Tow Rig"
1988 Jeep Comanche
2.5L 4cyl - 4 speed manual
2001 Jeep Cherokee Sport
4.6L Golen Engine Stroker
6.5" TnT Customs Longarm Kitl Ford 8.8" w/ disc brakes l 6.5" Rock Krawler Coils l TnT Customs HD Trac Barl Omix Ada HD SYE l 1" UBEsl CV Driveshaft l 35" Maxxis Bighorns l 15 x 8 Cragar Black Soft 8s (4" BS) l High Clearance Shock Mounts l 4 - BAJA off road lights l TnT Customs D30 Truss l Hidden Hitch l ARB Front Diff Cover l AJs Custom Front Bumper l SONY Xplod stereo l Alpine Speakers l TnT Frame StiffenerZ l 22" RE SS Brake Lines l 1.5" TnT Customs Boomerang Shackles l HP D30 l JKS Mini Skids and Sway Bar Brackets l TnT Customs OTK Steering
bmyohn is offline   Reply With Quote
Old 01-26-2009, 08:14 PM   #8
4pointOH1998
I will be doing mine with a Dremel. I'm planning on setting aside an entire day for it as I plan on making it look as clean as possible.
Pretty much any tool will work as long as you have patience and a steady hand.
-Bryan- ΚΔΦ-MΘΣΝΔ
Fighting the rust since April '08...
A Maine XJ Nightcrew!
4pointOH1998 is offline   Reply With Quote
Old 01-26-2009, 08:17 PM   #9
xjfever
forum supporter
xjfever's Avatar
1995 XJ Cherokee
Just don't use a sawzall, it will bend the fender up as it hangs in the metal. Don't ask me how I know.
Old 01-26-2009, 08:18 PM   #10
4pointOH1998
What must have seemed like a good idea spiraled wildly out of control.
-Bryan- ΚΔΦ-MΘΣΝΔ
Old 01-26-2009, 09:16 PM   #11
xjfever
forum supporter
xjfever's Avatar
1995 XJ Cherokee
Yeah, once you remove the inner liner and top brace those front fenders are pretty flimsy. The sawzall will catch the metal, and rip it back and forth before you can get it off. It leaves little split places and nice wrinkles along your new fender edge.
Old 01-26-2009, 09:32 PM   #12
lordChase
yes this is true my i used a frickin sawzall and have regreted it ever since, my fender was in bad shape before but you can see it got all bent out of shape when cutting it.I'll clean it up someday.?
lordChase is offline   Reply With Quote
Old 01-26-2009, 10:15 PM   #13
dcorn
Let me save you a lot of trouble by telling you not to use a dremel. I tried that and got through about 1/3 of one fender after going through a full 5 pack of the reinforced cutting wheels.
I promptly went out and bought a 4.5" angle grinder and easily took care of the rest of the job. Got a flap sander wheel also and it smoothed everything out very nicely. The cutting wheel on the grinder went right through the metal while it took me 2 passes with the dremel to get through and disintegrated the cutting discs.
I clearanced my front fenders more in the front and back because of the 4" BS wheels made my tires come really close to the metal when turning.
FOR SALE 1998 Cherokee Classic - White
5" lift - 35" tires - locked/geared/shafted/armored
2012 Subaru WRX Limited
dcorn is offline   Reply With Quote
Old 01-27-2009, 08:01 AM   #14
sean883
sean883's Avatar
I think the dremel is the best tool for the job. I used 7 or 8 of the reinforced cutting wheels and had both front fenders trimmed neatly in a little over an hour.
sean883 is offline   Reply With Quote
Old 01-27-2009, 08:51 AM   #15
rc76
Never done a fender trim myself... but with this write up (and now responses) I am not so afraid to approach the job when the time comes. Thanks!
98 Cherokee Sport- 4.5", AA SYE and TW Shaft, 33" Cooper Discoverer STTs, XCr8000, Jcroffroad Stage 2 Winch Bumper , 60" Hi-lift, Cobra Ultra III, Gragar Soft 8s, Detour Tail Bone, jcr Offroad Stage 2 Sliders, RockCrusher Diff Covers Front, Lockright in the front, Aussie in the Rear (Ford 8.8) with 488s... More $$$ for Bank Account (On Back Order...)
99 Cherokee Sport- Stock and Staying that Way (Wife's DD)
Christian Jeep Group Member #160
rc76 is offline   Reply With Quote
Glock Forum
