February 2007 C.O.M. **Modified Class** vote here
| View Poll Results: vote for the February 2007 Cherokee of the Month **Modified Class** | |||
| txjeep103 |
24 | 16.55% |
| sharpie1k |
18 | 12.41% |
| Haleyes |
25 | 17.24% |
| RandysCJ |
74 | 51.03% |
| joshs1ofakindxj |
4 | 2.76% |
| Voters: 145. You may not vote on this poll | |||
#1 | |
The Post man
Entry #1
txjeep103 1998 Jeep Cherokee Sport ~ 4 door ~ 68,xxx miles ~ 4.0L inline 6 ~ AW4 ~ NP 231 ~ K&N Air Filter ~ dana 30 with aussie locker ~ chrystler 8.25 LSD ~ Rubicon Express 4.5 super flex lift ~ Pro Comp X-Terrain - 33x12.50 ~ AR black steelies ~ Custom front bumper ~ Ramsey 8000 lb. winch ~ trimmed fenders ~ no fender flares, side trim or bumper end caps ~ Surco Safari roof rack with 4 KC daylighters, hi-lift, full sized spare, and autozone backup lights ~ throttle body spacer ~ glass pack ![]() ![]() Entry #2 sharpie1k 1998 Jeep Cherokee Sport 133,000 and change miles 4.0L AW4 NP231 PORC SYE with rebuilt stock front driveshaft MOPAR t-case skid plate Front Dana 30 Rear Dana 35 (Dana 44 being built with high clearance shock mounts, Alloy USA axle shafts, and a still undecided locker) Rubicon Express 4.5" Super Flex (full springs) RE Monotube shocks RE adjustable track bar RE Gen 2 disconnects Airaid cold air intake Poweraid throttle body spacer 32x11.50x15 Maxxis Bighorns OR Fab Rock Slider Bumper with grille hoop and shackles 2 Hella 550's mounted in bumper Pioneer 200watt head unit Pioneer G-Series speakers all around ![]() ![]() Entry #3 Haleyes 1996 XJ Police Special setting at 5.5" 4.0, AW4, NP 242 Rusty's 4.5" Coils /w/ spacer S-10 Bastard packs /w/ 2" shackle 33" Maxxis Bighorns on Cragar Soft 8's 4.10's Dana 30 /w/ LockRight & Warn Diff. guard Ford 8.8 /w/ Aussie & RuffStuff Specialties HD Diff. Cover Hack and Tap /w/ PowerDrive DS RE Adj. Trackbar (TNT Trackbar is in the mail) Homebrew Crok style inner steering box brace(outer is bumper tie-ins) OEM Gastank skid JKS Mini Skids. JKS Quicker Disco's Rusty's adj.LCA's Rusty's adj UCA's Rusty's TC skid JCR Stage 2 Sliders JCR Stage 4 front bumper /w/ frame tie-ins JCR Stage 3 Rear tire carrier bumper /w/ tie-ins Go Jeep H/L harness upgrade Aux. Backup lamp. Electric Fan override switch OEM Tranny cooler Hayden Power Steering cooler Uniden CB Hi-Lift Jack Tow straps 20lb. Co2 tank in the works. Lots of trail scars ![]() ![]() Entry #4 RandysCJ 1990 Comanche Eliminator Engine: 4.0 (stock) Imco Pro Series exhaust Drivetrain: AX-15 NP231 J-10 Axles D44 front, 4.88, lockright AMC20 rear, 4.88, Powertrax No-Slip Suspension & Steering: Front leaf conversion using 4" Pro Comp YJ Leaves Spring over rear with 2" fullsize Chevy AAL's Crossover steering using KOZ Offroad high steer arm Wheels and Tires: 15x10 Eagle Alloys 37x13.50r15 Baja Claw radials Recovery: JCROffroad front bumper Homemade rear bumper, d-ring shackle receiver Misc: rock lights Sony CD player Pioneer bass tube TJ flares ![]() ![]() Entry#5 joshs1ofakindxj 1989 Jeep Cherokee Limited Engine - 4.0L with Rusty's intake, K&N 6x9 Filter, Rusty's 1" throttle body spacer, 92 XJ radiator and open cooling system conversion, Optima yellow top, dynomax cat-back Transmission - AW4 with homemade grenade shifter T-Case - NP242 with an RE H&T SYE Tires - 31" Uniroyal's Rims - 16x7 aluminum Grand Cherokee stock wheels painted black Lift (3.5") - FRONT - Rustys HD 3" coils, homemade shock extensions with BPEs and homemade sway bar disconnects, Rustys brake line extension brackets, hockey puck extended bump stops, REAR - AAL done with 3/4 ton chevy leafs under XJ main leaf, removed sway bar, 3 degree shims, 1/4" block, homemade shock extentions with BPEs, adjustable air shocks, Rustys brake line extension brackets, Quadratec 4" bump stops Axles - high pinion, non-vaccum disconnect dana 30 and factory trak-lok'd dana 35 without c-clips Modifications - homemade front differential guard, homemade front bumper with brush guard, homemade trailer hitch, homemade rear tire carrier, electric fan switch, big sound system, lots of exterior lighting, back-up light switch, wagoneer front end conversion, rear floor storage compartments, cup holders and low-profile center consol, 1" hood lift, homemade transmission skid plate, homemade half doors for summer, homemade rock sliders, and a homemade cowl-induction hood ![]() ![]()
#2 |
German car snob
another competitive month
- Brian Klein Concept and Design KCD Website Follow us on Facebook! XJ Writeups: | DOORLESS IN A 97+ | D44 SWAP | REBUILDING A CV DRIVESHAFT | HOME-BREWED CENTER CONSOLE |
#3 |
I've gotta go w/ the MJ. That thing is bad ***
Current Jeep condition: SOLD :*( |
#4 |
why sint mine in here? did i enter wrong?
North Jersey Jeep Club Member- #83 www.northjerseyjeepclub.org the rig: http://img402.imageshack.us/img402/8980/jeep2xq0.jpg CHECK OUT MY BAND- www.myspace.com/myrtleave |
#5 |
why isnt mine in here? did i enter wrong?
#6 |
German car snob
no, Eric picks the most-abled five out of the bunch and puts them in the running.
#7 |
Very nice specimen of an MJ for sure!
#8 |
sharpie1k's got my vote but all of you guys have great lookin' rigs. Good luck!
BTW, the MJ is bada$$!
Colorado Jeep Club Member #76
#9 |
I hate to wig out and not pick a Cherokee but that MJ is what wet dreams are made of!
Nationalmssociety.org Current = 1996 XJ, 2.5, 2-Door, 5-Speed, 4.88's, SYE, 3.5" Mix-N-Match OME + RE, Black 15" KMC XD122's, 31" BFG AT's, RE QD's My current XJ build thread My old ZJ build thread Previous builds 99-XJ, 98-XJ, 89-XJ, 05-TJ, 95-ZJ, 79-J10 FOR SALE: RE 4.5" AAL for XJ, Reese Hitch for XJ, PM me for details on either |
#10 |
sharp you got my vote because our jeeps are twins...
#11 |
Go MJ
#12 |
cowl hood and cow catcher
That is a sweet hood and bumper you got there Josh!
How much to 62843? |
#13 |
Sorry fella's, I've always been an MJ man at heart, that thing takes the cake, look at that badass cherokee crusher, lmao, just kiddin.
1984 Suzuki SJ410, 1.3L 5speed, soft top, spoa, shackles, bodylift, 6 offroad lights. 1988 Dakota, 318, 5 speed, 4.10's, rollbar, lowered 3". 1986 2dr XJ, 2.8, 5 speed, Bushbar, 1989 XJ, 4.0, AW4, NP231, D44, 3.73's, *Stolen* 1987 MJ Sportruck, 2.5, AX5, Rollbar, *Jeep Heaven* 1986 MJ, 2.5, T-5, bushbar, Longbox, *Jeep Heaven* |
#14 |
German car snob
the MJ is
us.he really should be ![]()
#15 |
josh you got my vote! i love the hood.
Nice rigs all! |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
