Quantcast Father son jeep - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > Father son jeep
TJ 5.25" Speaker Adapters - NalinMFGFree Shipping on TIRES at KrawlOff-RoadGenuine Italian leather shift boots for your Jeep!
Old 05-13-2007, 09:25 PM   #1
Jayhawk077
Father son jeep
me and my dad are looking at cheap jeeps to fix up and do some serious off roading this summer before i head off to college. we found a cheap 93 jeep that cranks and is getting fuel and spark but doesnt run. it has new plugs, cap and rotor. what tests should we do too find out the problem?
R.I.P. my old XJ
[B]my cardomain website[/B]---[URL="http://http://www.cardomain.com/ride/2323251/1"]http://http://www.cardomain.com/ride/2323251/1[/URL]
Jayhawk077 is offline   Reply With Quote
Old 05-13-2007, 09:36 PM   #2
JeepXJsport12
My dad is buying a 95 XJ with only 1 flat tire and what looks like new exterior paint for 50 bucks! And yes it does run. Great condition.
O yea forgot to mention he knows the junkyard owner.
[QUOTE]Originally Posted by [B]madrabbitt[/B]
you need a big CHEROKEE sticker. something like a foot high and 3 feet long.
then people will know what you drive.[/QUOTE] [URL="http://www.cardomain.com/ride/2630344"][COLOR="Navy"]Blue Jeep Club #234[/COLOR][/URL]
[COLOR="Navy"][SIZE="4"][[/SIZE][SIZE="2"][][/COLOR][COLOR="Silver"]|||||||[/COLOR][/SIZE][COLOR="Navy"][][SIZE="4"]][/SIZE][/COLOR] Got That Custom Chrome Grill SANN
JeepXJsport12 is offline   Reply With Quote
Old 05-13-2007, 09:37 PM   #3
severous01
compression and leakdown tests.
compression test will tell you if there's even enough compression to run properly...they should all be withing about 10psi of each other, and should all be over 100psi ringing in about 150.
leakdown test will tell you which valves/rings or if a head gasket is needed. if you have air leaking into the throttle or exhaust, you'll need to break down the head. if you have air leaking into the coolant you need to replace the head gasket. and if you have too much air leaking into the crank case (through the oil cap) you'll need to breakd down the whole engine and put new rings/bearings in it. leakdown shouldn't be more than about 30% with an engine with over 100k miles on it.
the tools, both of them together...shouldnt cost more than about 50 bucks...and you can re-use them in the future when buying used cars.
severous01 is offline   Reply With Quote
Old 05-14-2007, 06:31 AM   #4
Jayhawk077
what else could it be beside compression or leakdown? timing belt maybe? if so how would i test that? i want to know any possible thing that could be wrong so we dont have to make that many trips
R.I.P. my old XJ
Old 05-14-2007, 09:57 AM   #5
XJH-007
I drank what?
XJH-007's Avatar
WTF? You want a Brownie Point or something??
Anyway..........
Check the CPS (CrankShaft Positioning sensor) and fuel rail for fuel. Are the plugs wet? getting spark?
Also: If your going to be doing some "serious wheeling" you better get a manual real quick and start study'n it..... So you know some of the basics like, XJ's don't have "timing belts".
Scott-Crawlorado Native
I have an addiction.....
*00' XJ_T-n-T Y-Link/6" RE_OME's_33" KM2's
Tera 4:1 / 4:56's_Elec. Locked D44
**84' CJ7 4"BDS 33's
***02 WJ Overland
XJH-007 is offline   Reply With Quote
Old 05-14-2007, 01:47 PM   #6
JeepXJsport12
Decided i would mention a good deal i got while it was close to the subject. Sounds like someone is jealous...
Also:
Wanna read the question before giving him a usless answer?
Old 05-14-2007, 04:51 PM   #7
severous01
timing chain test:
1. get cyl 1 to tdc and mark crank hub and block, or mate to 0* mark or TDC mark on the hub. if your crank has marks, use them, if no marks, make them....got it??
2. once the marks are aligned at TDC, rotate engine counter clock wise, from the front pulley or bolt, and measure degrees until one of two things happen...one, the rotor under the cap starts to move, or the rockers start to move if you dont want to remove the cap.
3. on an engine with 100k miles, 8* is ok, no more than about 10. you'll see up to 20* on engines that havent been kept or have tons of miles...they need to be replaced. like i said, any more than about 8* and you'll start having low rpm problems. you wont notice too much at higher rpms.
or, if you already took off the cover and have access, there should be no more than about 3/4 inches of play at the longest part of the chain...between the crank and cam sprockets
Old 05-14-2007, 06:55 PM   #8
Jayhawk077
thanks for all the help guys. and for the record ive been a proud owner of an xj for over 2 years i just have never had to do any major repairs like replaice a timing chain or gaskets. only minor tune ups. anything else you guys can think of? i really appreciate all the help. hopefully i can get this xj running so we can have some fun in it
R.I.P. my old XJ
Old 05-14-2007, 08:21 PM   #9
gregmondro
I have no tech input at this point because it sounds like you're set for now. I'd just like to say this sounds like a great project to do with your dad.
99 Jeep XJ - NP231, SYE, 4.56's, Rear D44 w/ Detroit SoftLocker and a RockCrusher Diff Cover, 35x12.5 BFG A/Ts, RE 5.5" XD Lift, Skidrow TC Skid, ORT Rear Bumper + Carrier, Rigidco Front Winch Bumper + Steering Box Plate, Milemarker 8000 Winch, Rock Sliders, HD Currie Steering, Control Arm Skids, Goferit Tie Rod Flip Insert, Optima Red Top and a few other goodies...
FiveZeroFive
XJ 8.25 Rear End Disc Brake Conversion For Sale!
gregmondro is offline   Reply With Quote
Old 05-14-2007, 08:58 PM   #10
iwishihad1
jump on this opportunity. i really wish i could do stuff like this with my dad...we get along pretty good, but he has no interest in jeeps and definately none in working on them. hes more of the why work on something if it isn't broke, and just doesn't get what im into about it i guess
iwishihad1 is offline   Reply With Quote
Old 05-14-2007, 09:11 PM   #11
JeepXJsport12
Same here, are you sure we don't have the same dad?
Old 05-14-2007, 09:15 PM   #12
UltimatE
Resident Audio Guru
UltimatE's Avatar
OT: Are you going to KU next year?
-Matt
White '94 YJ Sport
Black '98 ZJ Laredo - 45x60 Surco Rack - 2" Budget Boost, Addco Front Swaybar
Project (s)Low - A build log.
UltimatE is offline   Reply With Quote
Old 05-14-2007, 11:17 PM   #13
Jayhawk077
i am actually and im super pumped for it. rock chalk jayhawk baby! oh and my dads mostly there for guidance and the wallet. he will get dirty but would rather watch me do it. im fine with that as long as he shells out the cash to make this a decent trail rig
R.I.P. my old XJ
Glock Forum
