Fast clicking noise after 4.5" lift... - JeepForum.com
post #1 of 15 Old 03-25-2002, 11:48 PM Thread Starter
TopGun
Post Fast clicking noise after 4.5" lift...
Just finished my lift, now when driving I notice a nasty sounding click. I can get it to stop if I give it more gas, it also starts up just coasting with no gas. Sorry kind of a ****ty description, but anyone know what's going on? I'm still a jeep newbie... Also, this is in 2wd and I didn't notice this when I drove it before I had the alignment done this morning.
TopGun is offline
post #2 of 15 Old 03-26-2002, 12:18 AM
Kenny 96 XJ
Kenny 96 XJ's Avatar
Post
I got exactly the same thing at around 100km/h (60 mph), but goes away at 110 km/h...
When you lift your truck, you change the angles of your driving shafts which have not been designed to work at such high angles. What you hear is simply a little vibration and it is normal after a lift. It may settle after a while, but if you want to get rid of it, you will probably need a SYE (Slip Yoke Eleminator) and a new drive shaft...
What is scary is DW (death Wobble). This occurs while driving over little bumps on the road, the steering starts to rattle and shake like hell. The only way to stop this is to slow down...
To solve DW on my truck, I simply replaced the cheap Good Year Wranglers marked "economical" in their book to better tires. When I put these tires back on my truck, DW starts over again. This is not the case with my 31" Yokohamas or my 225 winter radials.
96 XJ Sport having the 6 cyl engine as the ONLY factory option
4" custom lift, 31" Yokohama Geolandar A/T + II, Quick disconnects, no rear sway bar
Kenny 96 XJ is offline
post #3 of 15 Old 03-26-2002, 12:23 AM Thread Starter
TopGun
Post
Well, I dropped the t-case 1", this is on a '92 with the 242, I don't FEEL any vibes, I dunno, it doesn't seem like that's it.
TopGun is offline
post #4 of 15 Old 03-26-2002, 01:04 AM
EricsXJ
The Post man
EricsXJ's Avatar
Post
Does the clicking sound like its coming from the front, rear, or middle of the jeep? and Does the clicking speed up and slow down as the jeep's speed changes?
Eric
2000 XJ "PROJECT RUBICON" 3-link front / 4-link rear / coilovers / running 37's on Dana 60s
My website -
EricsXJ is offline
post #5 of 15 Old 03-26-2002, 09:34 AM Thread Starter
TopGun
Post
As best I can tell it sounds like a front end noise. And yes it does speed up/slow down depending on how fast I'm going.
TopGun is offline
post #6 of 15 Old 03-26-2002, 11:51 AM Thread Starter
TopGun
Post
Ok, I just drove it to work, have some more details.
Does it at any speed, in 4wd or 2wd, sometimes off and on, not constant, seems to get worse when I hit a bump.
TopGun is offline
post #7 of 15 Old 03-26-2002, 04:05 PM Thread Starter
TopGun
Post
Anyone? I need this every day for work and I'm scared to drive it while it's doing this <img border="0" title="" alt="[Frown]" src="frown.gif" />
TopGun is offline
post #8 of 15 Old 03-27-2002, 01:07 AM
EricsXJ
The Post man
EricsXJ's Avatar
Post
I'm not the best at trouble shooting these kind of things so I'm not going to throw out any wild guesses But, here's what I would do based on that you just installed a lift and didn't have the clicking before I assume. I would take some time and crawl under there, make sure every nut and bolt is tightened down and there is no play in anything. Look at everything you touched or replaced including wheels. I'd also be looking at things like brake lines rubbing on the tires and such. Also I'd look at the front driveshaft - U-joints? Then if you didn't grease anything after the lift I would do that now.
Eric
My website -
EricsXJ is offline
post #9 of 15 Old 03-27-2002, 08:12 PM Thread Starter
TopGun
Post
Well I checked all the bolts, everything is tight, greased everything. Could a bad u-joint sound like this? It even makes this noise while braking sometimes.
TopGun is offline
post #10 of 15 Old 03-29-2002, 01:14 PM Thread Starter
TopGun
Post
Last try here...
If you've ever heard a CV joint going bad it sounds exactly the same as what I'm hearing on the jeep. It's not consistant, so I don't think it has anything to do with the drive shaft, but who knows. It's a very metal on metal rattle/click.
TopGun is offline
post #11 of 15 Old 03-29-2002, 10:57 PM
EricsXJ
The Post man
EricsXJ's Avatar
Post
One way to tell for sure wether or not its your front driveshaft or U-joints is to completely remove it. Drive it around this way and see if you still have clicking sounds. If you do, you know its something else. If the clicks go away, reinstall the driveshaft and see if they reappear.
Eric
My website -
EricsXJ is offline
post #12 of 15 Old 03-29-2002, 11:13 PM Thread Starter
TopGun
Post
Good idea, I'll give that a try tomorrow. Could I do the same thing with the rear DS? put it in 4wd and basicly turn it into a front wheel drive?
TopGun is offline
post #13 of 15 Old 03-30-2002, 11:57 AM
EricsXJ
The Post man
EricsXJ's Avatar
Post
Tecnically, Yes - but I don't see how that would help you diagnos the clicking in the front
Eric
My website -
EricsXJ is offline
post #14 of 15 Old 03-30-2002, 03:09 PM Thread Starter
TopGun
Post
Well it's hard to pinpoint a noise when you're driving with your haed sticking out the window, so I'm not positive it's a front end noise <img border="0" title="" alt="[Wink]" src="wink.gif" />
I pulled the front DS, noise is still there. Almost positive it's the rear drive shaft now.
TopGun is offline
post #15 of 15 Old 03-31-2002, 09:29 PM
EricsXJ
The Post man
EricsXJ's Avatar
Post
Very well could be the rear driveshaft since you upped it 4.5" increasing the driveshaft angle. Still stock driveshaft I presume? If so, before you think about spending any money on the u-joints, now may be the perfect time to do a SYE and longer CV driveshaft if you need one.
Eric
My website -
EricsXJ is offline
fast clicking sound when accelerating xjeep86 XJ Cherokee Technical Forum 11 10-15-2015 04:58 PM
Fast paced clicking in drivetrain aero3685 XJ Cherokee Technical Forum 5 07-10-2009 07:16 PM
Help with clicking noise! edgie92 XJ Cherokee Technical Forum 2 01-04-2009 02:17 PM
Fast clicking sound under acceleration, any advice???? Stockernotforlong XJ Cherokee Technical Forum 7 09-13-2002 05:31 PM
Squeaking/Squeeling noise in turns and Clunking/clicking noise when braking Sackdragger XJ Cherokee Technical Forum 3 05-14-2002 07:04 AM
