Failed CA Smog on NOx -
post #1 of 2 Old 03-28-2002, 12:02 PM Thread Starter
Post Failed CA Smog on NOx
88 Limited XJ 4.0 Auto.. failed only the NO test badly at about 1400 each should be 1200 at 15 mph and 800 at 25.. The CO and HC where very good way below mins ... So I think the cat and the engine is good just something in the NOx system.. any help out there ?
lordgrommit is offline
post #2 of 2 Old 03-29-2002, 08:08 AM
I just had my XJ inspected a few weeks ago. The guy at the shop said it passed with flying colors. He also said cherokees are very hard to pass because the EGR valve is junk. I would try that first, it should be an easy fix.
96 Black Classic
Safari Rack
Gibson Cat-back
3" lift in future with 31 M/Ts
CozmoClassic is offline
In order to be able to post messages on the forums, you must first register.
Failed California smog. need help please compfreak530 XJ Cherokee Technical Forum 10 08-13-2008 01:43 AM
help failed smog in CA mannyportie XJ Cherokee Technical Forum 3 01-08-2008 06:01 PM
95 4.0 failed smog jkmhb XJ Cherokee Technical Forum 7 04-28-2004 03:54 PM
California Smog Test - Failed Sky4boys XJ Cherokee Technical Forum 3 11-28-2003 09:30 AM
smog check FAILED!! what needs to be fixed? assang XJ Cherokee Technical Forum 7 03-23-2003 12:38 AM
