External Voltage Regulator Help ASAP!! - Page 3 - JeepForum.com
post #31 of 38 Old 12-28-2011, 11:12 PM
Boodyrider
Have you changed the alternator fuses yet?
97 TJ Sport - 4.0/HP D30 w ARB/8.8 w LS/4.88s; 35s and flat fenders on 2.5 lift
84 CJ7; frame off restoration in progress.
The technical advice you get from me here is worth exactly what you paid me for it. Warranty issues will be reimbursed at double what you paid me for the advice.
Boodyrider is offline
post #32 of 38 Old 07-10-2012, 08:00 PM
spyder98
Reviving an old thread i decided to go with a voltage regulator instead of a new ecu....i installed a voltage regulator and still alternator won't charge. I connected it exactly how its stated here green wire with a thin orange i sliced that and connected it to the ignition then my field wire from the regulator directly to the alternator am i missing something?
spyder98 is offline
post #33 of 38 Old 07-10-2012, 08:02 PM
spyder98
Both of the tabs on the black box where bent backed and tapped should i have left them alone? Still bolted to the alternator?
spyder98 is offline
post #34 of 38 Old 05-03-2013, 07:33 PM
LyferXB9s
Im bumping this up. Anyone figure out how to get these working?
Metal Smith from Hell in the US Navy. AM3(AW) 2008-present
LyferXB9s is offline
post #35 of 38 Old 05-27-2013, 03:21 PM
LyferXB9s
so I got mine working but now I have a cel and check gauges light. anyway to fix that?
post #36 of 38 Old 09-10-2013, 05:28 PM
dunitic
Did you find A way to get the cel off ?
dunitic is offline
post #37 of 38 Old 12-02-2014, 02:33 PM
Gweedo77
This is the kit that I ordered to fix this problem on our jeep. http://store.alternatorparts.com/hd-...ement-kit.aspx
Gweedo77 is offline
post #38 of 38 Old 01-27-2017, 06:53 PM
SmashinTJs
Reviving this thread for some troubleshooting help.
I have installed this kit: http://store.alternatorparts.com/hd-...ement-kit.aspx
and I believe that everything is properly connected. My power source is a piggy back fuse to a 10amp in the glove box.
My Jeep will now run again but after about 30 seconds the voltage on my cluster spikes above 19 and my check guage light comes on. The dash lights also pulsate as well as my headlights.
I have touched a multimeter to the ground points the regulator and the alternator and my voltage reads between 14-14.8 every location that I touch. The kit includes the FRM piece that is supposed to be connected between the wires that run back to the PCM. I have not used this piece but my understanding of this kit is that the FRM is strictly for fooling the computer into thinking the system is normal and keep the CEL off. My CEL is not on despite not using the FRM (yet).
Could I just be getting a false reading on the dash gauge? Maybe bad ground somewhere?
I would prefer to not start a ripping electrical fire.....
RED 1997 Modded TJ l 3.5 Rancho l PIAA's l 33'' KM2 l Custom Yakima Roof Setup l Armor l.
TJ TECH BOOT CAMP: READ IF NEW
Help us form the JF Search and Rescue Team
Originally Posted by scavanau View Post
Is that bumper weighted to keep you from catching air at highway speed?
Originally Posted by NorthWhiteWolf View Post
Well no (why would it) :confused:
Because I think your fender flares could easily pass for wings
SmashinTJs is offline
Voltage Regulator? kernalklink XJ Cherokee Technical Forum 12 09-16-2014 09:44 AM
External voltage regualtor bypass? xjunkie8796 XJ Cherokee Technical Forum 4 01-25-2009 11:15 PM
voltage regulator? internal or external? bc yj'er XJ Cherokee Technical Forum 0 11-09-2008 10:15 PM
Voltage Regulator on an 89 XJ MUDBOG101 XJ Cherokee Technical Forum 1 01-26-2008 03:15 PM
voltage regulator XJCHIEF XJ Cherokee Technical Forum 9 01-02-2004 07:08 PM
