Extended Brake Lines Front + Rear Junkyard For Lifts - JeepForum.com
post #1 of 9 Old 11-07-2011, 06:45 PM Thread Starter
fedx95
1993 XJ Cherokee
Ok, I already used the search function. Theres plenty of info about this, but its not all too good organized. I want to use this info as well as make it easy for others to know what brake lines to use. So, there's some useful info here to get us started.
http://www.jeepforum.com/forum/f11/p...hoses-1102060/
BUT, it must be deciphered by the JeepGods on the forum soooooooo
Front XJ Lines: Whats available (specify what year, make, model, increased length)
Rear XJ Lines: Whats available (specify what year, make, mode, increased length)
Please specify if you are talking about lines for the front or rear of the XJ, and if the lines came from the front or rear of the donor vehicle. If you have used the lines personally please mention that too.
Fire Away!
fedx95 is offline
post #2 of 9 Old 11-08-2011, 09:08 AM
PR1AWRet
2002 KJ Liberty
Please DO NOT use junk yard brake lines. Buy new ones. Now if this research is for getting the additional length from said vehicle to buy NEW ONES, I'm all for it.
PR1AWRet is offline
post #3 of 9 Old 11-08-2011, 09:10 AM Thread Starter
fedx95
1993 XJ Cherokee
I know YJ lines work but which work where
fedx95 is offline
post #4 of 9 Old 11-08-2011, 10:39 PM Thread Starter
fedx95
1993 XJ Cherokee
Anybody???? I wan't to buy front and rear lines, as mine are limiting flex (which is not good or safe).
So far by my research, what i Definitely know:
----Chevy Truck Front lines for the front of the XJ and are good for more 4"+ lifts
IDK whether to use front or rear dakota lines for the front or rear of the XJ.
Any suggestions will be very much appreciated
fedx95 is offline
post #5 of 9 Old 11-10-2011, 01:52 PM
PR1AWRet
2002 KJ Liberty
I made up a list, it's not complete but gives you some info for Chevy/Durango ones. Look at the 1990 Cherokee as a possible rear one.
http://www.jeepforum.com/forum/f11/c...-info-1287722/
PR1AWRet is offline
post #6 of 9 Old 11-10-2011, 03:12 PM Thread Starter
fedx95
1993 XJ Cherokee
96 dakota 4x4 rear line is 6" longer for the rear of XJ
Thanks PR1AWRet, lets continue to compile a comprehensive list
fedx95 is offline
post #7 of 9 Old 11-10-2011, 03:14 PM
AmbuGrl
AmbuGrl's Avatar
I have a 4.5in lift and we used a rear line from a 95 YJ to gain the extra length.
- HM1(SW/AW)Ret USN Dec 23,1992 to Dec 31, 2012
I drive an XJ, and all of my power windows work :)
2000 Pontiac WS6 - DD
DD (Mine) Sold - 98 XJ Moss Green
(His) - 92 YJ December 2013 YJOTM
Sold - 95 ZJ
Sold - 97 XJ Red
Sold - 98 XJ
USN Jeep Club Hull #36
NAXJA #3700
Originally Posted by RacerX View Post
WTF is Clockspring??? my Jeep has digital clock
AmbuGrl is offline
post #8 of 9 Old 11-10-2011, 05:53 PM
david92xj
1992 XJ Cherokee
you can relocate the factory front ones and get an extra 2 inches out of them.
i straightened my hardlines out a little more than in this picture. im pretty sure the one in the pic has abs, mine only has one harldine on each side.
david92xj is offline
post #9 of 9 Old 12-24-2011, 04:38 PM Thread Starter
fedx95
1993 XJ Cherokee
I ended up getting 97 RAM 1500 rear brake line. About 6" longer. Still have to install. Shouldn't be that hard, right?
fedx95 is offline
brake , extended , lift , lines , xj
extended front brake lines LVLF4LO XJ Cherokee Technical Forum 14 10-19-2010 06:28 PM
Extended Brake Lines RussoGuitar XJ Cherokee Technical Forum 10 05-21-2007 08:15 AM
extended brake lines? froggo27 XJ Cherokee Technical Forum 13 01-31-2007 07:15 AM
extended brake lines and abs johnisawesome XJ Cherokee Technical Forum 1 03-31-2005 11:07 AM
Extended Brake Lines AndyXJ XJ Cherokee Technical Forum 1 08-31-2002 12:59 PM
