#1 | |
extended brake lines and abs
ok well i have my 4.5 inch lift on and the brake lines are becoming an issue. for right now all i did is bend the hard line strait and relocate the brakets both front and rear. recently while taking it out one of the front brackets ripped off because they are still the limiting factor in axle droop. my question is not really about the brake lines but about the abs sensor wires. how do i go about extending those. and while your at it what do people recommend for new brake lines. id like to go ahead and get extra lond ones because sooner or later im going to to shackle and spacer up to 6 inches. thanks. tucc.
#2 |
www.lp.org
I'd solder in lengths of wire to match your lift. If you're looking for a total of 6 inches, solder in 6 inches of wire.
"'Did you ever wonder why we had to run for shelter when the promise of a brave new world unfurled beneath a clear blue sky? " Roger Waters |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
