#1 | |
extended brake lines?
i have a 3.5 inch lift on my xj with no extended brake lines do i need them? if so where do i get them?
#2 |
forum supporter
Go to your local auto parts store, and get a 95 wrangler rear line. It will be 3 to 4" longer and a direct swap.
#3 |
And for the front you can get lines from the same year wrangler and be good, or you can unbolt the hardline and move it down a ways.
1994 Jeep Cherokee 4x4 4.0 HO, Auto, 4dr., NP231, 8.25 rear 6 inches of bastard pack lift, 35/12.5/R15's Aux. fan switch, homemade BPE's moved intake, OEM towhooks Rear disc brakes, JKS disco's |
#4 |
thnks ill do that soon
#5 |
Do i really need them ive put about 10k miles on my jeep since having a lift and i havent had problems
#6 |
If you're just running on the street you can get by without them. Once you start flexing the suspension to the extremes off road you are likely to rip your brake lines off.
=====_____ /__l_l_,\____\,___ l_---l_l__l---[o]llllll[o] _.(o)_)__(o)_)--o-)_) |
#7 |
thts wa i thought thnks
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
