Quantcast Extended Brake Lines - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > Extended Brake Lines
TJ 5.25" Speaker Adapters - NalinMFGSpartan Lockers FREE SHIPPING Excellent PricesRough Country Deals at JeepHut.com
Old 05-21-2007, 01:14 PM   #1
gregmondro
http://www.fivezerofive.com/main/index.php?itemid=1047
Yesterday I went to go bleed my front brakes on the Jeep. I went to go loosen the bleeder screw on the passengers side front caliper and bumped the braided steel brake line with the handle of the ratchet. To my surprise the brake line broke clean off! Definitely not good, but it broke at the perfect time. I'd of hated to have it break on me when I was driving or out in the middle of no where.
Being that the Jeep is lifted, it had Rubicon Express braided steel brake lines up front that were longer then the stock brake lines. Since it was Sunday, Desert Rat and 4 Wheel Parts were both closed, so I headed to NAPA to try and find some replacement lines that would still be longer then stock.
The Rubicon Express lines were 22" long.
The replacement lines that I picked up from NAPA were 25" long.
Here is a little comparison shot of both lines hanging off of my winch fairlead.
As you can see the NAPA rubber lines have a metal bracket in the center. This is just bent around the line and you can bend it off or cut it off (don't damage the lines!)
The part number for the NAPA 25" long brake hoses that fit on my 99 Jeep Cherokee was 380534.
Part #
The price for two lines (I opted to replace both front lines and use the one that wasn't broken as a spare) was just around $60.
Hopefully this can help someone out that is looking for longer brake lines locally (or in my case, locally on a Sunday when everything else was closed.)
99 Jeep XJ - NP231, SYE, 4.56's, Rear D44 w/ Detroit SoftLocker and a RockCrusher Diff Cover, 35x12.5 BFG A/Ts, RE 5.5" XD Lift, Skidrow TC Skid, ORT Rear Bumper + Carrier, Rigidco Front Winch Bumper + Steering Box Plate, Milemarker 8000 Winch, Rock Sliders, HD Currie Steering, Control Arm Skids, Goferit Tie Rod Flip Insert, Optima Red Top and a few other goodies...
FiveZeroFive
XJ 8.25 Rear End Disc Brake Conversion For Sale!
gregmondro is offline   Reply With Quote
Old 05-21-2007, 01:39 PM   #2
XJH-007
I drank what?
XJH-007's Avatar
Were they off a 1990 Chevy C1500??
Scott-Crawlorado Native
I have an addiction.....
*00' XJ_T-n-T Y-Link/6" RE_OME's_33" KM2's
Tera 4:1 / 4:56's_Elec. Locked D44
**84' CJ7 4"BDS 33's
***02 WJ Overland
XJH-007 is offline   Reply With Quote
Old 05-21-2007, 01:54 PM   #3
gregmondro
Not sure offhand. I've seen a list before with some extended lines, but I can't seem to find the link today.
The guy at the parts counter was kind enough to browse through their brake hose book for a while until he found these for me.
FiveZeroFive
Old 05-21-2007, 02:14 PM   #4
IntrepidXJ
doesn;t look like the same part number as the GM's
http://jeepforum.com/forum/showpost.php?p=3755182&postcount=11
Randy Langstraat
.: myXJ.net :.
IntrepidXJ is offline   Reply With Quote
Old 05-21-2007, 10:15 PM   #5
MGrobe
Man In Black
MGrobe's Avatar
What a shock, another broken SSB brakeline!
To remove the brackets from the Chevy 1500 brakelines, I used a vise to hold the bracket secure and then took a vise grips to grab the part of the bracket that is wrapped around the brakeline. I used the vise grips to peel back the bracket from the brakeline. Took no more than 15 seconds per line and zero damage was incurred on the brakeline.
-Marc-
Sweet Pea 1998 - XJ
http://www.grobe.us/Jeep
- JeepForum Rules - Become a Premium Member or Vendor
For Sale: (4) AR 767-5766 Wheels (used) 15x7, 5x4.5, 4.5BS - for local pickup in the Chicago-area
MGrobe is offline   Reply With Quote
Old 05-22-2007, 10:15 PM   #6
mud-dog27
i just did mine uses brake lines off a 95 yj worked fine and now i have lotsa room for flex
89 wagoneer LTD. , 32x11.5R15 wild country RVT, 15x8 AR baja rims , surco safari roofrack w/spare tire kit , cobra 19 DXIII w/ high gear mic. 4' whip on a 3" heavy-duty spring , 4.5" rough country full leaf pack lift kit
My Jeep's Page
mud-dog27 is offline   Reply With Quote
Old 05-22-2007, 11:34 PM   #7
XJK
The Guru of Nothing
XJK's Avatar
looks good, thanks for the information. I hope my braded RE lines hold up better then yours did
-Kyle
XJK is offline   Reply With Quote
Old 05-23-2007, 08:42 AM   #8
1992 cherokee
Anyone have a part number for a longer rear brake line?
1992 cherokee is offline   Reply With Quote
Old 05-23-2007, 09:11 AM   #9
gregmondro
I'm going to have to figure a way to get the metal part off mine with them installed. I bled all 4 corners the day after i installed them and now it brakes better then it did when i bought it. the stainless lines failed because i over extended one before i had my bump stops set up properly.
FiveZeroFive
Old 05-23-2007, 09:12 AM   #10
gregmondro
I'm going to have to figure a way to get the metal part off mine with them installed. I bled all 4 corners the day after i installed them and now it brakes better then it did when i bought it. the stainless lines failed because i over extended one before i had my bump stops set up properly. by the way. i think yj lines measure 21 inches. thats why i didn't use them. they are too short for me.
FiveZeroFive
Glock Forum
