Exhaust Sound Question - JeepForum.com
post #1 of 16 Old 09-15-2010, 12:20 PM Thread Starter
Willemcuracao
1994 XJ Cherokee
Hi everyone,
I have a 1994 cherokee sport 4.0
Im planning on putting 2.5 inch piping and taking my cat off, but im leaving my stock muffler. how will this sound? is it worth it or should i buy another muffler right away?
Thanks,
__________________________________________________ ____________
1994 Jeep Cherokee Sport 4.0 With 45.000 miles! 3 inch Series II Rough Country Lift Kit - Rough Country Steering Stabilizer - Good Year Wrangler AT/S 31 x 10.50 - Black Steel Brushguard - Blue LED's Under Dashboard, Seats & Trunk - IPF Headlights & White Bulbs ( Throttle Body Spacer & Cold Air Intake Coming Soon)
Willemcuracao is offline
post #2 of 16 Old 09-15-2010, 01:17 PM
dukie564
1995 XJ Cherokee
don't take the cat off, at least not if you ever want to drive on the road again - just get a high-flow cat.
and the stock muffler sounds terrible, get a flowmaster!
This is mine: 95XJ with magnaflow cat, flowmaster super 40, and custom mandrel bent 2.5 tailpipe
YouTube - Jeep Cherokee Flowmaster Super 40 + Magnaflow Cat Exhaust Sound
YouTube - Jeep Cherokee Flowmaster Super 40 + Magnaflow Cat Exhaust Sound 2
1995 XJ Cherokee Sport
4.5" Homebrew Lift, 4.0L HO I-6, AX-15, NP231, D30(Open)/C8.25(Locked)
33x12.5 Mickey Thompson Baja MTZ Tires, 309,000 mi and runnin' strong
dukie564 is offline
post #3 of 16 Old 09-15-2010, 01:34 PM Thread Starter
Willemcuracao
1994 XJ Cherokee
thanks for the info! I was looking at the flowmaster delta 40 series. how is that one? i heard it has a nice aggressive sound. but why should'nt i take the cat off? there are no rules about it where i live.
post #4 of 16 Old 09-15-2010, 01:42 PM
dukie564
1995 XJ Cherokee
Delta 40 isn't as nice as the super 40 IMO.
As far as the CAT, do you live in the USA? if so it's illegal.
You will gain little to nothing by removing the CAT.
Also, by removing the CAT, you lose the exhaust backpressure that your engine likes to run correctly. Also, it will smell terrible when moving slow.
dukie564 is offline
post #5 of 16 Old 09-15-2010, 01:47 PM Thread Starter
Willemcuracao
1994 XJ Cherokee
i dont live in the us. so if i order just the super 40 muffler. 92 dollars on flowmaster.com and my shop here will put the full 2.5 inch piping it will sound good right? do you still have the stock piping? which of the ones on here do i need? Super 40 : Flowmaster Inc. Exhaust Shop, Love That Sound!
thanks alot man,
ill make a video of my jeep when its done
post #6 of 16 Old 09-15-2010, 02:18 PM
dukie564
1995 XJ Cherokee
You need 2.25IN Center, 2.25OUT Offset for stock piping.
I kept my stock 2.25" downpipe, have a 2.25" I/O CAT, 2.25" I/O Muffler, swedged the end of the 2.5" tailpipe to fit OVER the outside of the muffler outlet port for better flow.
Here is the main differences between their series:
Delta 40 - More compact, aluminized, low interior resonance, aggressive exterior sound
Super 40 - Bigger than Delta and 44, Black, Medium interior resonance, aggressive exterior sound
Super 44 - Black, high interior resonance, aggressive exterior sound
dukie564 is offline
post #7 of 16 Old 09-15-2010, 05:07 PM
alexrule123
alexrule123's Avatar
Here is my red one and I rev it to about 3k rpm in the video.
I had an APN header, full 2.5" exhaust and borla muffler
2001 Cherokee Limited:
2005 Pontiac GTO 6.0L (DD)
alexrule123 is offline
post #8 of 16 Old 09-15-2010, 07:21 PM Thread Starter
Willemcuracao
1994 XJ Cherokee
alright thanks! srry for asking again. but if i put the 2.5 piping which one would i need then? thanks guys
post #9 of 16 Old 09-15-2010, 07:27 PM
jjshbetz11
I SWEAR I am not lying but I just took off the mufflre and straight piped it with a 2" 1/4 resonator pipe to take up the difference of the muffler. It sounds identical with the first video. I also run a header though. Also, it's a H.O Head
jjshbetz11 is offline
post #10 of 16 Old 09-16-2010, 06:49 AM
dukie564
1995 XJ Cherokee
The only way you're going to get a full 2.5" piping is to replace the exhaust header and downpipe. I'm not sure how much that would cost but unless your header is cracked and your downpipe is rusted out it's not worth it. I would just run the stock piping until it gets below the truck, then neck up with an adapter to 2.5". If you do that before the muffler, get the 2.5IN Center / 2.5OUT Offset. If you do it after get the 2.25I/O
dukie564 is offline
post #11 of 16 Old 09-16-2010, 11:06 AM Thread Starter
Willemcuracao
1994 XJ Cherokee
Here's my plan: im not putting the cat back on. and then i'll do like you said the 2.5 piping after the downpipe.
I'll get the flowmaster super 40. no the only thing is ordering and waiting untill it gets here. which can take a while. anything else i would be needing? then i can order everything at once.
post #12 of 16 Old 09-16-2010, 11:09 AM
dukie564
1995 XJ Cherokee
nope just have the exhaust shop take care of the rest (piping, clamps, hangers, etc)
dukie564 is offline
post #13 of 16 Old 09-16-2010, 01:11 PM
Ninety5poloz
Well my '01 has a 2.5" down pipe and necked down right after the cat. So I removed the cat, welded in a 2.5" stainless I pipe into a 2.5" magnaflow muffler and a mandrel bent 2.5" stainless tailpipe. IMO it sounds good below 3k rpms but gets poppy above that. And its a little loud for a DD, but I can always make it quieter, but I'm not too concerned with it right now, right now I need more lights
Ninety5poloz is offline
post #14 of 16 Old 09-16-2010, 05:19 PM Thread Starter
Willemcuracao
1994 XJ Cherokee
@dukie564: What do you mean by this? I would just run the stock piping until it gets below the truck, then neck up with an adapter to 2.5". If you do that before the muffler, get the 2.5IN Center / 2.5OUT Offset. If you do it after get the 2.25I/O
Im confused about which one i have to order.
i appreciate the help! the guys where i live are not so helpfull/don't know a lot
post #15 of 16 Old 09-17-2010, 06:55 AM
dukie564
1995 XJ Cherokee
you have 2 options if you keep the stock downpipe:
1) where the CAT would attach to the downpipe, put an adapter to go from 2.25 to 2.5, and run 2.5 piping from that point back - in this case buy a 2.5IN Center / 2.5OUT Offset muffler.
2) keep 2.25" piping until you get to the muffler, get a 2.25IN / OUT muffler, then attach a 2.5 tailpipe (this is what I did to make things easier and because my CAT was 2.25In/Out).
dukie564 is offline
cherokee , exhaust
Exhaust Sound Question Cherokeekid88 XJ/MJ Cherokee Non-Technical Forum 3 08-06-2009 09:37 PM
Will an exhaust tip interfere with the flow/sound of the exhaust Habib66 XJ Cherokee Technical Forum 7 07-20-2009 07:14 AM
Exhaust sound clip! iowaneedshills XJ Cherokee Technical Forum 3 03-13-2006 10:22 AM
Exhaust Sound & Tips bmg97 XJ Cherokee Technical Forum 8 12-27-2005 10:22 PM
Exhaust sound SouthernJeepn06 XJ Cherokee Technical Forum 4 08-10-2005 12:24 PM
