Exhaust manifold crack symptoms? - JeepForum.com
post #1 of 11 Old 03-02-2006, 12:55 PM Thread Starter
cobra7
What are the typical symptoms to tell if you have a cracked exhaust manifold, aside from removing the intake manifold and inspecting it? Are there tell-tale signs?
COBRA7
2000 XJ Classic (Black on Camel) | 4.0L I6 | AW-4 | NP231J | Dana 30 | Chrysler 8.25
cobra7 is offline
post #2 of 11 Old 03-02-2006, 01:16 PM
LEAD_NOT_FOLLOW
LEAD_NOT_FOLLOW's Avatar
1989 XJ Cherokee
Easiest way to tell is if you have a "ticking" sound, thus exhaust leak. Also your idle may be a bit iratic, and you'll have a bit of loss in power.
LEAD_NOT_FOLLOW is offline
post #3 of 11 Old 03-02-2006, 03:22 PM Thread Starter
cobra7
Well, I have a ticking sound when I first start it up until it warms up, then it's gone. My idle surges very slightly by maybe only 50 RPM or so.
I don't know about a loss in power, cause I bought it used only around 4 months ago and it's my first Jeep, so I don't know how much power it should feel like to tell the difference.
Would the ticking occur all the time or just at certain times, like when it's cold? Reason I ask is, I'd love to get a Banks header, and having a cracked manifold would be a great excuse for the wife!
At the same time, I don't wanna spend the money right now if I don't have to, but if it is cracked, I will.
COBRA7
cobra7 is offline
post #4 of 11 Old 03-02-2006, 04:05 PM
dsarraf
dsarraf's Avatar
Are there any visiual signs bsides cracks? Vapor emmsions?
dsarraf is offline
post #5 of 11 Old 03-02-2006, 04:31 PM
Thayer
That ticking sound at startup might be your emissions vapor solenoid valve opening and closing. Touch it on your firewall and see if the ticking sound is coming from that, you'll feel it clicking.
1997 Cherokee Sport NAXJA #1255
RK 4.5" LA Kit
Thayer is offline
post #6 of 11 Old 03-02-2006, 04:51 PM
Lundy
Not certain about the ticking, though my engine ran considerably louder. This was difficult to tell as the problem had been progressive. After the new headers were on though, the reduced engine noise was pronounced. A crack usually appears at the point where the two down pipes converge into one. Check this area when the engine is cold, as once the manifold heats up the cracks will sometimes close up on you. Other than that, the engine may feel a little sluggish compared to what you are used to, though the best diagnosis will be a visual inspection.
If you do have cracks and are to replace the manifold, I strongly recommend the Banks Torque Tube. Their work is beautiful, the welds are clean, and it comes with a great warranty should you ever need it. As for the install, it is relatively simple until you find that one bolt somewhere in the middle of the flange. Try not to get frustrated, just plan on spending some quality time making 1/4" turns with a crescent wrench.
Lundy
Lundy is offline
post #7 of 11 Old 03-02-2006, 08:49 PM
lma1973
Mine used to tick after it was warm. Also the exhaust was loud but i really only noticed it was loud after i got the new manifold and heard how quiet it was. That and i had SO much more power and the MPGs increased and it ran MUCH better and smoother.
lma1973 is offline
post #8 of 11 Old 03-02-2006, 10:14 PM Thread Starter
cobra7
Hmmm, OK it sounds like I can inspect for the crack from under the Jeep. I thought I would have to remove the intake manifold to check for it. So that's good. I'll check that out.
I'll check the vapor emissions solenoid to see if that's the source of the clicking I hear. I thought maybe it was a crack in the exhaust manifold and that maybe the ticking stopped because the cracks closed up ones the manifold heated up.
Yes, I planning on getting the Bank TorqueTube header at some point. If my manifold is cracked, I'll get it now. If now, I'll get it later this summer. It does look like a nice piece. My plans are an Airaid TBS, the Banks header and a Flowmaster 40 exhaust.
COBRA7
cobra7 is offline
post #9 of 11 Old 03-02-2006, 11:22 PM
Lundy
You should be able to see the crack from under the hood. Take a look from the driver side of the engine bay, just below the brake fluid resevior. With a flashlight you can usually spot the culprit with no problem.
Lundy
Lundy is offline
post #10 of 11 Old 03-03-2006, 04:20 AM
greenbeater
greenbeater's Avatar
1968 FSJ Wagoneer
Lundy
what he said can see my cracked junk no prob from there...
his - 68' Wagoneer, 455 Pontiac, tons
hers - 00' XJ tail rig D44, C9.25, 4.56
ours - 01' WJ 4.0
greenbeater is offline
post #11 of 11 Old 03-03-2006, 07:48 AM Thread Starter
cobra7
Great. Thanks!
COBRA7
cobra7 is offline
Replacing exhaust manifold due to crack, need advice viper719 XJ Cherokee Technical Forum 11 03-14-2009 03:25 AM
The Inevitable Exhaust Manifold Crack Invictus XJ Cherokee Technical Forum 6 10-09-2007 01:10 PM
Exhaust manifold crack question miketyson XJ Cherokee Technical Forum 4 03-02-2007 10:08 AM
Crack in exhaust manifold--How to?? XJ-NoDough XJ Cherokee Technical Forum 5 06-21-2005 02:23 PM
Exhaust Manifold Crack Jeepnstein XJ Cherokee Technical Forum 21 03-24-2005 10:30 AM
