Exhaust hanger fix - HATE this %$#@# Jeep - JeepForum.com
post #1 of 4 Old 05-04-2012, 03:11 PM Thread Starter
Lonewolf92c
1995 XJ Cherokee
Everything is hard on this damn Jeep.. LOL
Need some ideas gang...trying to fix exhaust without buying whole new one.
The hanger on passenger side of tranny mount normally looks like this:
As I got the jeep, mine looks like this (no hanger):
So..I bought this:
I think it will work, but damn if I can get it in.
Hints? Tips? Anyone used this combo?
I guess I could have the end ground "pointed" but don't have tools. Thanks in advance for any advice!!
"Where am I going and why am I in this hand basket?"
"Searching for peace of mind...."
SEMPER FI
Lonewolf92c is offline
post #2 of 4 Old 05-04-2012, 04:49 PM
Diamond-x
1991 XJ Cherokee
The two pictures show two different hanger types, you already know this. The first is simply a round rod, inserted in the round isolator. In the second picture the isolator is for a half-round. You can make one by finding tubing that is close to the isolator curve, cut it conically so you can slide it in the isolator. By conically I mean cut the tube in half, then taper one end. Then weld your round rod hanger to the conical insert. An option would be to sharpen the end of your isolator and slide it in. That's what she said.
Diamond-x is offline
post #3 of 4 Old 05-04-2012, 08:52 PM
lilnapsak
1997 XJ Cherokee
since you have no tools.. heat up a steak knife on your stove, run outside and cut the rubber out until its a round hole for your new hanger to slide into.
lilnapsak is offline
post #4 of 4 Old 05-05-2012, 07:33 AM Thread Starter
Lonewolf92c
1995 XJ Cherokee
Can't see the forest for the trees....
To lilnapsak & Diamond-x
Thank you for reminding me that "elegant" is not always the best solution...its a utility vehicle not a show vehicle...LOL
I'll prob go with grinding out the rubber...
Thanks!!!
SEMPER FI
Can you ID this exhaust hanger?? Lonewolf92c XJ Cherokee Technical Forum 3 04-23-2012 05:42 PM
exhaust hanger flyjeeptings XJ Cherokee Technical Forum 1 03-15-2012 11:24 PM
Rear Exhaust Hanger Need Pic GotBeat5.0 XJ Cherokee Technical Forum 6 08-13-2009 04:40 PM
Damn Jeep's rear exhaust hanger came "unglued" 95xjnick XJ Cherokee Technical Forum 9 01-23-2009 07:28 PM
exhaust hanger phmaris XJ Cherokee Technical Forum 1 01-23-2009 12:56 PM
