Is this a ex sheriff jeep - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > XJ Cherokee Technical Forum > Is this a ex sheriff jeep
Only 2 Days left to win $3,800 Jeep Parts!Security Deck EnclosureSPARTAN LOCKERS are on sale BIG TIME at ROCKRIDGE 4WD!
Unread 01-11-2015, 04:55 PM   #1
bcameron1974
Recently got this jeep and it had stripes on it. I can see where it head light bar. It also has a plug coming out of bumper? Few antenna wiring and toggle switches.
my build thread.http://www.jeepforum.com/forum/f12/my-sahara-rebuild-thread-1990-a-784008/1990 YJ 4.2 nuttered-mc2150-team rush-4 inch RC-1.5''-Shackles-1 1/2''-15x10 American Racing Atlas Wheels-33x15x12.50 Goodyear A/T-Hella Offroad Winshield Lights-Black Met/Gold Paint -Custom Gold Decals
bcameron1974 is offline   Reply With Quote Quick reply to this message
Unread 01-11-2015, 04:58 PM   #2
bcameron1974
Here's before stripes removed
my build thread.http://www.jeepforum.com/forum/showthread.php?t=7840081990 YJ 4.2 nuttered-mc2150-team rush-4 inch RC-1.5''-Shackles-1 1/2''-15x10 American Racing Atlas Wheels-33x15x12.50 Goodyear A/T-Hella Offroad Winshield Lights-Black Met/Gold Paint -Custom Gold Decals
Unread 01-11-2015, 05:01 PM   #3
bcameron1974
Trying to figure out without paying for a car fax
Unread 01-11-2015, 05:05 PM   #4
bcameron1974
I noticed it had skid plates also. Do Cherokees come stick with?
Unread 01-11-2015, 05:42 PM   #5
wizardPC
Could be a police package, or could be a fleet jeep. Does it have a switch for ext idle? Would be down by the rear wiper switch.
http://GunsCarsTech.com
If I've never pissed you off, give it time.
wizardPC is offline   Reply With Quote Quick reply to this message
Unread 01-11-2015, 05:44 PM   #6
bcameron1974
No idle switch
Unread 01-11-2015, 05:44 PM   #7
bcameron1974
Did have light bar on at one time.
Unread 01-11-2015, 05:48 PM   #8
bcameron1974
It has 100 mph cluster.
Unread 01-11-2015, 05:57 PM   #9
sjones26573
Offroad NC State
sjones26573's Avatar
Exhausted my Google-fu abilities. Came close, but no dice. Did find some inspiration though.
However I believe that is an active police vehicle. You could do the whole getup, it just would have to be a trail rig only.
The Yellowtail Build
Originally Posted by Jeremy Clarkson - Top Gear Botswana Special
Why don't all cars have no doors? When I come to power I'm going to make it a rule because this is just better.
sjones26573 is offline   Reply With Quote Quick reply to this message
Unread 01-11-2015, 06:00 PM   #10
sjones26573
Offroad NC State
That's just a late model cluster I believe. XJ's and TJ's had 100 mph clusters.
Unread 01-11-2015, 06:05 PM   #11
sjones26573
Offroad NC State
Some info for you
http://www.allpar.com/squads/police-cars/cherokee.html
Unread 01-11-2015, 06:20 PM   #12
shooptube
1997 XJ Cherokee
Compare to this post.
Originally Posted by madrabbitt View Post
You want to know the exact diffrances between the police package and normal ones?
1. Shifter. Mounted on the column, not the floor. The 4wd shifter is mounted on the floor. There is no center console to allow for radio and siren mounting.
2. Alternator. 130 amp standard.
3. Carpet delete was standard with rubber flooring. Carpet was optional
4. Front and rear sway bars were thicker to reduce body roll. Also, gas monotube shocks were used.
5. Transmission cooler was standard
6. ABS was standard.
7. 1997 and newer models had standard Unity brand a frame mounted driver's side spotlights.
8. 92-96 models had no trim, black fenders, black grille. 97-01 models usually had body color fenders and bumper
9. They came stock with the heavy-duty steel 5 spoke wheels, and LT225/70HR15 tires
10. There is a gasket/plug in the driver's side B pillar for routing the lightbar cable.
The 4wd models came with the upcountry skid plating and tow hooks, the 2wd's only had the engine skid.
Scan of the 97+ sales flyer
1992 demo vehicle. I dont have a clue where i got this picture from
A ton of metal on your Jeep, different from, a ton of well-engineered metal on your Jeep.
shooptube is offline   Reply With Quote Quick reply to this message
Unread 01-11-2015, 06:23 PM   #13
pismo61
The police speedo go's up to 120 mph and the word "certified" is written in white below the Mph/kWh marking.
2000 XJ 4 door Auto.
pismo61 is offline   Reply With Quote Quick reply to this message
Unread 01-11-2015, 06:26 PM   #14
bcameron1974
Ok thanks. This does have skid plates on it and fits 30s with no rubbing. Is it possible it might of have special ordered the skid plates. I don't think my last cherokee had skid plates.
Unread 01-11-2015, 06:27 PM   #15
bcameron1974
By the stripes, what would have this been used for prob? Considering had a light bar.
