Erratic speedometer, fuel gauge, tach - JeepForum.com
post #1 of 4 Old 08-03-2005, 06:04 PM Thread Starter
hydraulic
I have a 1996 Cherokee classic. Recently, the gauges have gone haywire, flipping back and forth and then ceasing to function at all. I checked for a trouble code, but there isn't one. I changed the VSS (vehicle speed sensor), but it didn't do any good. Does anyone have a clue what could be the problem? Maybe the computer? How to check?
hydraulic is offline
post #2 of 4 Old 08-03-2005, 07:17 PM
elijah
Try cleaning the connectors in the back of the panel. It seems to be a problem in many jeeps. I have a 98 had to clean them. And there have been a few posts with instrument related problems.
XJ 4X4 1998 XJ Classic 4dr 4.0
Class III hitch
HD Trans cooler
Pilot Driving lights
Rally Roof Lights
31x10.5x15 Mickey Thompson Radial MTX
Outlaw II 15x8 3.7bs
RE6025 3.5" Super Ride w/ Rear Springs XJ
Pro Comp ES3000 shocks
Pro Comp Stabilizer
Full 1" drop for the crossmember bar
And no I do not have any vibes in the driveline
scratch that :
I now have some vibes. 11-17-2005
elijah is offline
post #3 of 4 Old 08-13-2005, 02:03 AM
racin4ever2000
clean and tighten the ground on the passenger side of the motor beside the oil filter, thats the ground for the gages
racin4ever2000 is offline
post #4 of 4 Old 08-13-2005, 07:35 AM
gpJeep
I had the same problem when my battery died.
I got a bost from the shopping store gaurd and drove home but all the indicators were going crazy because the old battery was shorting out continually.
Bought a new battery installed it and all is now fine !!
gpJeep is offline
fuel gauge/rev. counter/speedometer not working normandy XJ Cherokee Technical Forum 6 08-09-2010 08:46 PM
Dead Speedo, Tach, and Fuel gauge. Everything else works. Power5 XJ Cherokee Technical Forum 13 12-07-2009 07:03 AM
Oil Pressure Gauge acting erratic after Thermostat change anicetoemma XJ Cherokee Technical Forum 5 05-08-2009 11:47 AM
Erratic Fuel Guage CDH67 XJ Cherokee Technical Forum 3 09-11-2008 05:17 AM
Tach Indicator Erratic XJNewbeeA&PMech XJ Cherokee Technical Forum 4 02-19-2007 01:44 PM
