Eric's cage build - Page 13 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > Eric's cage build
Build your Dream Jeep with Poison Spyder's Interactive GarIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineRuffStuff Memorial Day Sale!
Unread 03-24-2010, 12:48 AM   #181
EricsXJ
The Post man
EricsXJ's Avatar
I really like the integrated look on the front! Very one of a kind.
I know you are going to do something about that pillar space because well, your Eric. Even if you have the doors off all the time the gap is going to get to you.
Let me think about that.
nope
I'm calling it good!
Eric
2000 XJ "PROJECT RUBICON" lifted, locked, shafted, running 35's, 4.56 gears, pair of ARB's, and stock AM/FM cassette
My website - EricsXJ.com
EricsXJ is offline   Reply With Quote
Unread 03-24-2010, 12:54 AM   #182
Hussler
1992 XJ Cherokee
You say that now... hahaha
Originally Posted by chris87xj View Post
Sometimes a restoration project is a labor of love, at which point cost, time, and labor involved become irrelevant.
Originally Posted by BorderC View Post
I see you also twizzled your scart lead. Well done! :thumbsup:
92 XJ with ARB's, 5" lift, too much armor, 33's and some other garbage
Hussler is offline   Reply With Quote
Unread 03-24-2010, 01:03 AM   #183
nrpalmer32
1987 XJ Cherokee
Very nice work Eric! I'm just learning how to weld, well getting better with practice, and this is definitely making me want to practice on a full roll cage! lol Anyways, great work!
Are you thinking about doing something like that for the rear? Making it integrated to some sort?
nrpalmer32 is offline   Reply With Quote
Unread 03-24-2010, 02:31 AM   #184
Jones
Consider the following...
Jones's Avatar
That's awesome! I'm jealous.
Jones is offline   Reply With Quote
Unread 03-24-2010, 07:14 AM   #185
Timo_90xj
Timo_90xj's Avatar
1990 XJ Cherokee
Originally Posted by EricsXJ View Post
And I was soo looking forward to driving it. But I decided to change the gear oil in the diffs and found I have two stripped bolt holes for the front diff cover, one of them being the very bottom bolt. It never fails....
Eric, your Jeep looks fantastic!
The gap bnetween a-pillar tube and doors is the same thing I'm facing. I saved my front fenders and thought about cutting a portion off of them to fill the gap. Should look nice and clean.
Tube doors for the summer huh? Let's see if you or me has them ready first?
..I've never liked the idea of running copletely doorless, I'm too scrared of something hitting me or my passengers if I roll the Jeep.
http://www.jeepforum.com/forum/f13/d...s-etc-1222317/
***Under construction***
1990 XJ (4-door), 4.0 I6, AW4, NP242, PBR 42" tires, Unimog 404 portal axles, 110" WB, full cage + uniframe completely rebuilt, front 3-link + panhard / double triangulated 4-link rear,...
http://www.jeepforum.com/forum/f11/h...ternal-973910/
Timo_90xj is offline   Reply With Quote
Unread 03-24-2010, 08:16 AM   #186
dcorn
Good point. Plus, Eric has mentioned a few times hitting rocks and stuff on the pillars and possibly ruining the stock hinges, so I would think tube doors (and even a piece to fill the gap between the cage and the front door) would keep the hinges front bending too bad.
1998 Cherokee Classic - White - 5" lift - 35" tires - locked/geared/shafted/armored
2004 Grand Cherokee Overland - Stock DD
dcorn is offline   Reply With Quote
Unread 03-24-2010, 08:28 AM   #187
BRad704
Nothing to see here...
BRad704's Avatar
As for the gap and hinges and doors. What about (i know you love hearing THAT!) using either tube, or flat stock or both, to fill the gap, and using the stock hing locations on teh doors, to bracket the hinges toward the outside edge of the door? Then you have the bar/tube filler that should definetly be strong enough to support a sleeve for the door pin. Yes, it makes the hinge point become external (TJ/YJ style), but it gives you 1) a way to protect the A-pillar, 2) a filler for the gap when full doors are on, and 3) a MUCH easier method for removing/installing either set of doors.
Hopefully that description made sense... I can see all this in detail in my head, just having trouble describing it.
BRad704 is offline   Reply With Quote
Unread 03-24-2010, 09:18 AM   #188
Timo_90xj
Timo_90xj's Avatar
1990 XJ Cherokee
You're the MAN! Why have I never thought of that? It actually makes a lot of sense, at least for the tube doors. And I don't think it should be too hard to figure out a way to mount the stock doors somehow like that.
Especially with the older style door hinges taking doors off and putting them back is a PITA.
Unread 03-24-2010, 10:23 AM   #189
BRad704
BRad704's Avatar
Thanks Timo... I wanted to do something like this on mine, but dont really have any justification for it.
My idea (for OEM doors) on the door hinge side was to use the stock bolt locations. Making hinge brackets that follow the door frame to the skin, follow the skin to the edge, then go just around the edge of the door.
Once that is done just locate the hinge sleeves (body side) onto the new pillar structure.
Tube doors could then be built off the now existing lower hinge sleeves.
EDIT: I didnt know people in Finland said "PITA"... I had to explain what it meant to my wife a few months back...
Unread 03-24-2010, 12:50 PM   #190
Timo_90xj
Timo_90xj's Avatar
1990 XJ Cherokee
Well, we don't But one ends up learning things by browsing through multiple forums that are in English
I gotta look into that door hinge solution, it really sounds like a good idea. Heck, after the first time I took off my doors I haven't been able to line them back up Should be much easier with external hinges.
Unread 03-24-2010, 03:17 PM   #191
JeepSpeed18
Amazing Eric, simply amazing!
_=====ooooo
//__l_l_,\____\,_____
l_/-\_l__l_/-\_|lllllll|
_\_/==== |; _\\ \\_|;
_(o)_)___(o)_)--o-)_)
96 Jeep Cherokee 4" lift with 32" KM2's
94 Jeep Cherokee 3" lift with 29's!
JEEP Just Empty Every Pocket my life moto. :)
White Jeep Club Member #109
Jessie The Jeep (lots of pics)
But yeah my 4.0 has been hydrolocked twice, ran upside down for 7 seconds it still keeps coming back for more. its like that crazy ex-girlfriend that just wont quit..but unlike her, its a good thing haha
JeepSpeed18 is offline   Reply With Quote
Unread 03-24-2010, 04:16 PM   #192
RussoGuitar
1989 XJ Cherokee
outstanding...
RussoGuitar is offline   Reply With Quote
Unread 03-24-2010, 08:00 PM   #193
leftlanetruckin
XJ on 37's
leftlanetruckin's Avatar
Excellent as ever Eric, good job!
I was in Sparks (Petro) from Sat night till Monday @2am this week, woulda been nice to grab a few cold ones
Will shoot you a PM next time I am through there.
Martin
1998 XJ on 37's.JK Rubi axles with chromo shafts and ctm's, 4:1 transfer case, etc etc etc.The Cherylkee....
2003 Range Rover HSE, 4.4 Quad Cam.
1998 Range Rover 4.6 HSE
2000 4.7 4WD WJ with a rebuilt motor.
4.3/700r4/new frame buildup (YJ)....
http://www.jeepforum.com/forum/f12/swap-offically-underway-324622/
Years to gain the hands on experience, and offer it freely.
Minutes to gain the knowledge from the internet, and quote it just as freely.
Choose wisely!
leftlanetruckin is offline   Reply With Quote
Unread 03-24-2010, 10:09 PM   #194
EricsXJ
The Post man
EricsXJ's Avatar
I think I know what you are describing. I think I'll let Timo prototype that one and then maybe I'll follow suit.
Martin
PM sent.
Eric
Unread 03-24-2010, 11:17 PM   #195
TheMULE1
1997 XJ Cherokee
this is one of the nicest, cleanest xj's ive seen, "Project Tarantula" use to be a inspiration to me and my xj, but damn eric your jeep is just simply passed that stage. You have done a lot more things that have caught my attention, simple things like limit straps on the stock uca brackets, hood vents, ect. very good work. hope my xj will look as clean as yours one day.
TheMULE1 is offline   Reply With Quote
cage , exo-cage , exocage , tube fenders
