Engine won't start - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > XJ Cherokee Technical Forum > Engine won't start
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineWIN a Rough Country Forged Track Bar - ExtremeTerrain!1987-2016 Wrangler Jammock Black 2.0 Jeep Hammock (YJ, TJ
Unread 12-17-2009, 12:30 PM   #1
97jeepgcl
Engine won't start
Hi, new member with question;
I have a 97 grand cherokee with the 4.0 and while at stop light engine just quits like the key was turned off, I have fuel pressure at the rail but had no spark, I have replaced the coil and crank position sensor and still it won't start...what else could it be, is the gap at the crank sensor that critical as it was a pain to change and I am not sure of the gap. Any help would be great.
Thank you,
Jeff
97jeepgcl is offline   Reply With Quote Quick reply to this message
Unread 12-17-2009, 01:54 PM   #2
compfreak530
compfreak530's Avatar
When you replaced the ckp did you remove the felt material from the sensor?
compfreak530 is offline   Reply With Quote Quick reply to this message
Unread 12-17-2009, 02:12 PM   #3
97jeepgcl
No because the directions said to leave it on and as the engine runs it will remove it, it said that was how you set the gap.
Unread 12-17-2009, 05:05 PM   #4
97jeepgcl
any other ideas?
