Engine won't idle - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > XJ Cherokee Technical Forum > Engine won't idle
BDS 4-1/2" Suspension Lift Kit - Jeep Wrangler YJRuffstuff 10 year saleRough Country Lift Kits and Parts!
Unread 12-27-2012, 11:22 AM   #1
jeeporiwalk
Engine won't idle
When my 2001 4.0 liter reaches running temperature, it refused to idle and cuts out. It starts up immediately yet still won't idle. Dealership ran diagnostics and a faulty cam sensor was said to be the blame.
We have replaced the following:
Cam sensor
Map sensor
Wiring from the cam to the injectors and inlet manifold sensors
Exhaust sensor and air flow sensor on inlet manifold (replaced these with working second hand parts)
CPS sensor recently replaced (with new Mopar part)
Dealership has had the vehicle for 5 weeks now and are stumped.
Pllllllleeeeessse help !!
jeeporiwalk is offline   Reply With Quote Quick reply to this message
Unread 12-27-2012, 11:36 AM   #2
tjwalker
It's the crank sensor!
tjwalker's Avatar
Is it still setting a code after doing what you did?
If so, please post the EXACT CODE number(s) here for the most accurate replies.
Gotta follow the codes. With OBD, the devil is in the details. OBDII isn't perfect to be sure, but it's awfully darn good at pointing to the offending circuit.
99 Cherokee, 4.0 AW4, NP242
Past Jeeps: 49 Willys, 81 Scrambler, 88 Comanche
Without "data", all you have is an opinion!
tjwalker is online now   Reply With Quote Quick reply to this message
Unread 12-27-2012, 12:04 PM   #3
jeeporiwalk
No code coming up now?
