Engine won't start - JeepForum.com
post #1 of 4 Old 12-17-2009, 11:30 AM Thread Starter
97jeepgcl
Engine won't start
Hi, new member with question;
I have a 97 grand cherokee with the 4.0 and while at stop light engine just quits like the key was turned off, I have fuel pressure at the rail but had no spark, I have replaced the coil and crank position sensor and still it won't start...what else could it be, is the gap at the crank sensor that critical as it was a pain to change and I am not sure of the gap. Any help would be great.
Thank you,
Jeff
97jeepgcl is offline
post #2 of 4 Old 12-17-2009, 12:54 PM
compfreak530
When you replaced the ckp did you remove the felt material from the sensor?
compfreak530 is offline
post #3 of 4 Old 12-17-2009, 01:12 PM Thread Starter
97jeepgcl
No because the directions said to leave it on and as the engine runs it will remove it, it said that was how you set the gap.
post #4 of 4 Old 12-17-2009, 04:05 PM Thread Starter
97jeepgcl
any other ideas?
Engine will not start when it's hot BuddhamanJB XJ Cherokee Technical Forum 3 10-18-2007 01:18 PM
New engine won't start 97powerstroke MJ Comanche Technical Forum 9 06-23-2006 06:21 AM
Won't start after engine cleaning Bob Marshall MJ Comanche Technical Forum 6 11-05-2005 05:43 PM
engine don't start help freedomhunter XJ Cherokee Technical Forum 2 07-21-2005 07:55 PM
engine do not start tayo88 XJ Cherokee Technical Forum 5 01-28-2003 03:54 PM
