Engine Will not turn/crank when cold? Binds? - JeepForum.com
post #1 of 1 Old 10-14-2009, 07:40 AM Thread Starter
pdigiacinto
I have a '88 Xj 4.0 that has a cranking issue. It seems to only happen when it is cold outside (temp is below 60-55 degrees). When I try to start the engine, it seems to "bind". The starter runs (plunger comes out), but the flywheel does not turn. I have to try starting it a few times and then the flywheel will finally turn and the jeep starts.
I thought it was the starter, so I put a new one on. That did not solve the issue. The engine has a a slight rapping when cold, and only has a slight rapp when driving. I did not hear the slight rapping in he summer, I only seem to hear it when the temperature is cold outside?
I left the jeep sit for a few days. When I went to start it, it did bind again. After I pushed on the gas pedal, it finall started and sounded like a slight backfire through the carb.
I have nocited that when I come to a stop light, the jeep will starve for gas and konk out sometimes. It starts back up and drives fine. This happens radomally. It will never die when driving, only when stopped or comming to a stop.
I do not think the fuel pump is bad. this has stumped me, since I cannot pinpont wether it is a engine or fuel issue.
Thanks.
pdigiacinto is offline
4.0 will crank but won't turn dketten XJ Cherokee Technical Forum 7 07-17-2009 09:59 AM
99 XJ: 4.0 will crank but won't turn covejeepsxj XJ Cherokee Technical Forum 6 01-09-2009 06:02 PM
4.0 will crank but won't turn stevejaz XJ Cherokee Technical Forum 7 11-11-2008 04:39 AM
Turn key no crank..HELP ddoffroad XJ Cherokee Technical Forum 4 05-07-2008 10:02 PM
help key wont turn in cold cold weather asjeep XJ Cherokee Technical Forum 5 12-08-2005 11:00 AM
