Engine swap=no fire - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > XJ Cherokee Technical Forum > Engine swap=no fire
Introducing MONSTALINERô UV Permanent DIY Roll On Bed LineSave on AEM Intakes from XT!Save 17.76% for the 4th of july with ruffstuff specialties
Unread 04-15-2015, 01:20 AM   #1
waffals
Engine swap=no fire
I've been reading through these forums for days and I'm lost still. So, here it goes. I did an engine swap on a 99 jeep Cherokee xj. I'm getting no fire from the plugs. I've been trying to weed it out by buying new parts daily and frankly, I'm stumped. New coil, cap and rotor, plugs, wires, stator. I'm getting no resistance on the crankshaft positioning sensor (after going through 2 of them). All grounds were Che led and cleaned, fuses are good. Everything that I can think of has been meter checked to make sure the proper voltage. IM NOW LOST! What else could it possibly be? The only thing I don't have, which I found in a threaded was the CAT 02 sensor is hooked to the ignition. Here in SC, don't really need a CAT, so pulled it. Can I bypass that? Thanks yall for any help I receive.
the jeep life chooses you, deal with it!
waffals is offline   Reply With Quote Quick reply to this message
Unread 04-15-2015, 05:40 AM   #2
CCKen
CCKen's Avatar
You might try swapping the ASD relay with the Radiator Fan relay and see if that works.
When you have the ASD relay out check the pin cavities for the relay for corrosion or the pin cavities shoved down in the PDC.
PDC:
If we have data, letís look at data. If all we have are opinions, letís go with mine.
CCKen is offline   Reply With Quote Quick reply to this message
Unread 04-15-2015, 11:12 PM   #3
waffals
Got it thanks. Changed the CPS for the 3rd time and switched the relays around. Fired right up and purred like a kitten. Thank you for your help.
