Engine Swap - Flexplate to Torque Converter? - JeepForum.com
post #1 of 12 Old 08-31-2012, 06:55 AM Thread Starter
bills79jeep
I'm in the process of swapping out a 4.0 for 4.0, and it's my 1st time. I got a "new" motor at the junkyard, and it's ready to go in. However, my Haynes manual says that I should index my flexplate to the torque converter with paint, so when I put it back together, I can line them up.
One, I can't do this because a different engine is going back in, so there won't be a mark on the new flexplate. I wasn't planning on swapping the flexplate to the new motor, should I do that?
Two, even if I wanted to mark them, I can't see the torque converter to make a mark on it. I have the inspection cover off, and the flexplate blocks any view I could have of the TC. Once again, the manual says to clamp the TC in so it doesn't come out with the engine, but I can't see it, let alone get a clamp on it.
I can't think of any reason they would need to be aligned in any special way, except maybe for the CPS. Are the bolt holes non-concentric, so there is only one way to bolt them up?
Thanks
2005 Grand Cherokee Laredo 3.7L, stock
1979 CJ-5 AMC V8
1998 Cherokee 4.0L - Sold
bills79jeep is offline
post #2 of 12 Old 08-31-2012, 07:01 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Haynes is on crack. Bolt the flexplate to the engine. Put it in.
cruiser54 is offline
post #3 of 12 Old 08-31-2012, 09:19 AM Thread Starter
bills79jeep
Thanks.
Do I need to do anything in regard to the CPS? I know it takes readings off the flywheel.
1979 CJ-5 AMC V8
post #4 of 12 Old 08-31-2012, 09:23 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Originally Posted by bills79jeep View Post
Thanks.
Need more info. What exactly are you working on and what year is the donor engine?
post #5 of 12 Old 08-31-2012, 09:30 AM Thread Starter
bills79jeep
I am taking the engine out my my 98 Cherokee, and putting in another 4.0 from a 96 Cherokee. From what I understand, it's the same motor. Currently, the donor motor has the flexplate still attached from the original Jeep.
1979 CJ-5 AMC V8
post #6 of 12 Old 08-31-2012, 10:33 AM
buildin1XJ
Use the flexplate,dist,coils,sensors,intake,TB from your 98 engine on the 96 engine you are installing so your wiring connectors on your harness will be able to connect.
buildin1XJ is offline
post #7 of 12 Old 08-31-2012, 11:11 AM Thread Starter
bills79jeep
I am using all of the accessories from the '98. Pretty much everything but the long block portion will be switched over to the '96 engine.
I was under the impression that the flexplate for the '96 and '98 are identical, do you have a reason that you'd swap it?
1979 CJ-5 AMC V8
post #8 of 12 Old 08-31-2012, 11:40 AM
ltrail
1984 XJ Cherokee
I would swap it if I wasn't sure. The 6 flexplate bolts could save pulling the tranny when it doesn't run. Haven't much experience with the obd2 4.0 so err on the side of caution. I'd swap them just so I was sure.
I swapped my 95 4.0 for a 98 and connectors are all different. So I put all the 95 goodies on 98 block. Head was different also. Make sure new head has same connection. My head has 2 coolant sensors, 98 donor had 1 and no hole in the rear of block where it should have been.
84 xj 350tbi, sm465, 203/205, 60/70. links and other junk.
what size sawzall blades does it take to fit 40's?
ltrail is offline
post #9 of 12 Old 08-31-2012, 12:02 PM
buildin1XJ
I myself am not certain whether the 96 and 98 flex plates are the same for certain but I would not chance it, as the pick ups that the CPS use could be slightly different.And when you change the two out remember that the holes in the flexplate and the end of the crankshaft will only line up in one position so you can not install it wrong.
post #10 of 12 Old 08-31-2012, 12:13 PM Thread Starter
bills79jeep
Thanks. I was aware that the flexplate-to-crank connection was that way, is the flexplate-to-TC the same?
1979 CJ-5 AMC V8
post #11 of 12 Old 08-31-2012, 12:38 PM
buildin1XJ
Flex to TC is simple get one bolt in and the rest will line up just get all four started before tighting them.
post #12 of 12 Old 08-31-2012, 08:28 PM
jr4x4
look at the part numbers on both flexplates & see if they match
jr4x4 is offline
engine swap , flexplate , torque converter
Engine codes pointing to torque converter. Symptoms include: ciguchi XJ Cherokee Technical Forum 8 04-28-2013 01:41 PM
torque converter relay-check engine light B_carney XJ Cherokee Technical Forum 0 06-28-2010 03:02 PM
Engine swap flexplate question. quesoisgood XJ Cherokee Technical Forum 1 04-30-2010 12:29 PM
Torque for flexplate/torque convertor bolts curtjames37 XJ Cherokee Technical Forum 1 03-27-2007 10:55 AM
how to get torque converter off engine rockhound XJ Cherokee Technical Forum 5 08-18-2006 10:44 AM
