engine swap from 4 cylinder - JeepForum.com
post #1 of 11 Old 04-15-2011, 10:44 AM Thread Starter
distncernr
1985 XJ Cherokee
Ok so my engine finally took a dump on me. I currently have the 2.5 4 cylinder in it and want to swap up to the 2.8 V6 cylinder (unfortunately my year doesnt have the 4.0 option, i have a 1985). I was wondering will I need to change my bellhousing or will it be the same for the 6 cylinder? I have the AX5 5-speed manual transmission.
Please let me know and thanks in advance for the help.
distncernr is offline
post #2 of 11 Old 04-15-2011, 11:08 AM
cbordea
do you have the 2.8 already? I don't know for sure but seems like I read that the 3.4 v6 that came in maybe the camaro was a much better engine, I don't remember all the reasons why.
88 MJ I6 4x4 Stock my hauler - Sold
98 XJ I6 4X4 Stock my son's DD
06 12V Purple Barbie Jeep my daughter's DD :-)
cbordea is offline
post #3 of 11 Old 04-15-2011, 11:14 AM
skullver
Tarpitz
1991 XJ Cherokee
I don't know about the trans issues as I had the whole drivetrain, but the rest wil bolt right up if you have the motor mounts for the 4.0, I put a 4.0L in my 85 jeepspeed.
Blah blah blah blah.
my Jeepspeed build thread:
skullver is offline
post #4 of 11 Old 04-15-2011, 11:17 AM
cbordea
I did a search for v6 swap and found a few threads, you might read through and PM some of those guys that have done it if they don't respond here.
http://www.jeepforum.com/forum/f11/e...2-8-a-1159912/
http://www.jeepforum.com/forum/f11/j...-swap-1170501/
http://www.jeepforum.com/forum/f11/8...3-4-a-1142876/
cbordea is offline
post #5 of 11 Old 04-15-2011, 12:59 PM
XJH-007
XJH-007's Avatar
I put a Buick 3.8L in my 84 XJ, in hindsight I would have/should have just sold it and got a 4.0 HO. I was like 18 and had time and no money
All sorts of issues arise upon motor swaps that aren't intended if you have to make it Emission legal, and want it to run right.
Even the 4.0 swap tot he 85 is not an easy one as the front clips are different, not to mention ignition, fuel management, etc.
IMPHO, scrap it and get a newer XJ.
Scott-Crawlorado Native
I have an addiction.....
*00' XJ_T-n-T Y-Link/6" RE_OME's_33" KM2's
Tera 4:1 / 4:56's_Elec. Locked D44
**84' CJ7 4"BDS 33's
***02 WJ Overland
XJH-007 is offline
post #6 of 11 Old 04-15-2011, 01:20 PM Thread Starter
distncernr
1985 XJ Cherokee
Thanks for all the info....so it probably wouldnt be worth all the trouble just to go to the 2.8 V6, not much gained there for all the headache?!?
post #7 of 11 Old 04-15-2011, 01:36 PM
XJH-007
XJH-007's Avatar
The 2.8 was a really problematic motor...it made little IF ANY extra HP's over the 2.5. The 2.5 was still being used as the XJ era came to an end...while the "Turd.8" was only used a few years.
***02 WJ Overland
XJH-007 is offline
post #8 of 11 Old 04-15-2011, 04:21 PM
Flyordie
1985 XJ Cherokee
It would probably be cheaper to rebuild the 2.5. Thats what me and my dad did but we put a few extra goodies into it. (I have the same model year, just with the AX-4)
If you don't want to rebuild it yourself then, yes.. its prolly best to scrap it and buy a newer Jeep.
btw- what crapped out on it?
Flyordie is offline
post #9 of 11 Old 04-15-2011, 06:43 PM Thread Starter
distncernr
1985 XJ Cherokee
either the head gasket or the head... i did a pressure test and all my cylinder read 175 and one of them read like 125
post #10 of 11 Old 04-15-2011, 06:51 PM
Flyordie
1985 XJ Cherokee
Yea, thats pretty low. Leakdown test maybe? Squirt a little oil in the "dead" cylinder and if it gets a better PSI reading, then its the rings. If it doesn't change, its the valves/head.
I am sitting at 200-210 PSI across all 4 of my cylinders. :-\
Flyordie is offline
post #11 of 11 Old 04-15-2011, 06:55 PM Thread Starter
distncernr
1985 XJ Cherokee
yea i think im just going to go get the valves and head redone and replace all gaskets and go from there
ZJ Master Cylinder Swap keaton XJ Cherokee Technical Forum 1 05-22-2010 08:07 AM
WJ Master Cylinder Swap xjguy98 XJ Cherokee Technical Forum 1 07-05-2008 08:18 PM
Master Cylinder swap? dmay1969 XJ Cherokee Technical Forum 9 04-04-2008 01:25 PM
4 Cylinder Swap Mtxz453 XJ Cherokee Technical Forum 5 12-03-2007 03:33 PM
6 Cylinder To 4 Cylinder W/o Swap Jeepthing88 XJ Cherokee Technical Forum 27 10-30-2006 07:40 AM
