Engine Swap - JeepForum.com
post #1 of 8 Old 04-27-2013, 06:58 PM Thread Starter
hardy
Engine Swap
Looking for a little advice.
I am replacing the 4.0 engine in my 98 Cherokee with a rebuilt older engine from a 94 or 95 Cherokee. Of course the head and block casting numbers are different but everything looks like it will interchange. I do plan to use the valve cover, intake and exhaust manifold from the 98 because there are a few differences.
If the flexplate the same or should I use the 98?
Are there other problems I might encounter???
Would I benefit from using the head from my 98 on the older engine.
hardy is offline
post #2 of 8 Old 04-27-2013, 07:01 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Not eonough to go to the trouble of changing the head.
Any 1990-2001 XJ Cherokee or 1993-98 ZJ Grand Cherokee 4.0 L engine block will interchange.
Remove and re-use as needed or required from your original engine: Intake/Exhaust manifolds, flex plate/flywheel, cylinder head, distributor-less ignition or distributor assembly, engine sensors, fan belt driven accessories and mounting brackets.
CJ7-Tim is offline
post #3 of 8 Old 04-27-2013, 07:06 PM Thread Starter
hardy
The distributor and coil look the same and I had not planned to exchange them. Will this be a problem?
hardy is offline
post #4 of 8 Old 04-27-2013, 07:07 PM
CJ7-Tim
CJ7-Tim's Avatar
Compare what you have to what the donor engine has. You may have to swap over some parts.
CJ7-Tim is offline
post #5 of 8 Old 04-27-2013, 07:12 PM Thread Starter
hardy
Thanks!!!
I am in the process of removing the old engine and everything is good until I got to those top bell housing bolts. I got the driver side out but can't get the socket on the pass side. I'm not sure what to do. I removed the motor mount bolt to lower the engine but still can't get on the stupid bolt. BTW...the one I got out seemed it was torqued about 100 lbs
hardy is offline
post #6 of 8 Old 04-27-2013, 07:28 PM
CJ7-Tim
CJ7-Tim's Avatar
Most people lower the rear of the engine by removing the transmission crossmember. Support the rear of the engine with a floor jack or transmission jack.
CJ7-Tim is offline
post #7 of 8 Old 04-27-2013, 07:34 PM Thread Starter
hardy
That was my next option. I guess I will need to put the motor mount bolts back in and remove the crossmember.....seems like lots of trouble to remove a bolt????
hardy is offline
post #8 of 8 Old 04-27-2013, 07:53 PM
dino30
Any 4.o will interchange .. there are some slight differences in the acc. mounting brackets when you get up to 99+ but i have an older 95 engine in my 99 Grand ... I used my intake , exhaust and my Distributor-less ignition system . I just used the main engine block , head , and covers from the older engine .. all my stuff bolted right up to it .. ...
As for the bolt . you need to remove the trans cross-member and lower the rear of the engine to get to it ...
Good luck ...
dino30 is offline
