engine starts rough idles for a few seonds and dies - JeepForum.com
post #1 of 1 Old 04-07-2012, 02:28 PM Thread Starter
corkit08
hi im new on here i just bought a 96 cherokee se 2.5l 5spd and i got it for cheap with engine problems i replaced the ditributer (not cap since still in good condition) ignition coil, spark plugs, fuel injectors and cps but nothing has changed.
to go into more detail i bought it not running at all started looking for spark and saw the plugs were bad (replaced them) and it was an orange color so i looked at the ditributer and the part that goes into the engine had shredded teeth on one side so then i got a new one but kept the same cap, looked at the spark and it was still a orangish color so i replaced the ignition coil and now i have blue/white spark all over,
it still wouldnt run but would turn over so i looked at the stock fuel filter and saw rusty looking color gas coming from it and regular color gas going into it so i bought a new one and flushed the lines (fuel pressure went back up) i decided to check the injectors to see if the were clogged and they were so i went out and got new ones and cleaned the rail no rust color inside of it.
checked the presure of the cylinders and they were fine did a bunch of trouble shooting and thought it could be the CPS so i went out and got a new one but now im stuck at where i am now it will start rough idle for seconds and die and if you touch the throttle it dies faster and the only engine code i have is for my AC because i had to disconnect it to do the distributer.
all the spark plugs and inector wires are hooked up right and the engine was at absolute 0 when i put in the distrubiter and it was put in right idk what else that it can be please help
corkit08 is offline
engine died , rough idle
Starts, idles rough until warm CJ51973 XJ Cherokee Technical Forum 1 09-05-2010 09:53 AM
96 4.0, Starts fine, EXTREMELY rough idle, dies very soon after start Jameslol XJ Cherokee Technical Forum 8 01-20-2010 08:39 AM
engine idles for 30 seconds then dies. toates89 XJ Cherokee Technical Forum 0 09-16-2009 04:27 PM
engine starts and dies right away truitt25 XJ Cherokee Technical Forum 7 04-13-2006 12:21 PM
HELP, Idles like a bucket of rocks, starts rough dirt machine XJ Cherokee Technical Forum 7 01-07-2006 01:37 PM
