Engine shuts off randomly!!!! - JeepForum.com
post #1 of 6 Old 10-08-2011, 07:39 AM Thread Starter
pjavan
My engine seems to cut off randomly. Almost as if someone is cutting the fuel to the engine. It doesn't bog down or anything, just when I come to a stop it just shuts off. Has no problems starting again though. Thoughts?
99 Cherokee 4.0L
pjavan is offline
post #2 of 6 Old 10-08-2011, 07:43 AM
skyway0018746
this happened to one of my jeeps it was low on oil and would shut off if it didnt have oil pressure.
7" long arm lift, HNT sye , herculined inside, bush wacker fender flares now geared and locked !!!
62 mm bored throttle body's fs - pm
skyway0018746 is offline
post #3 of 6 Old 10-08-2011, 10:17 AM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Is all your routine maintenance up to date ? Tune-up, fresh battery. Have you opened, cleaned with electrical contact cleaner, and reconnected all the wire plugs under the hood ?
Next you should test the CPS.
CPS/CKP failure is very common. Often this part is also referred to as the CranKshaft Position Sensor (CKP) The CPS/CKP can stop working with no warning or symptoms and the engine will not run or the engine may randomly stall for no apparent reason.
Typical Symptoms –
- The engine may randomly stall for no apparent reason.
- Starter cranks and cranks but engine won't start up and run.
- Fuel gauge and voltage gauge may not work or display properly.
- You sometimes will have No Bus on the odometer after 30-60 seconds.
- A failed CPS/CKP may or may not throw a CEL trouble code.
- No spark at the spark plugs.
- Fuel pump should run and prime for 3-5 seconds.
Begin with basic trouble shooting of the start and charge systems. Remove, clean, and firmly reconnect all the wires and cables to the battery, starter, and alternator. Look for corroded or damaged cables or connectors and replace as needed. Do the same for the grounding wires from the starter to engine block, and from the battery and engine to the Jeep's frame/body. You must remove, scrape, and clean until shiny, the cable/wire ends, and whatever they bolt to. Jeeps do not tolerate low voltage, bad connections, or poor grounds and the ECM/ECU may behave oddly until you remedy this.
Exchange the fuel pump relay and the ASD relay with one of the other similar ones in the PDC to eliminate the relays as the cause of the no-start. Check the ASD relay fuse.
Confirm that the fuel pump to runs for 3-5 seconds when you turn the ignition key to ON.
Eliminate the NSS as a cause of no start. Wiggle the shift lever at the same time you try to start. Put the transmission in Neutral and do the same. Do the reverse lights come on when the shifter is in Reverse?
Inspect the wires and wire connectors at the O2 sensors on the exhausts pipe. A short circuit from melted insulation or from broken O2 sensor wires can blow a fuse and the ECU/ECM will loose communication. Don’t get tunnel vision and assume the sensor is bad (unless it tests bad with a meter). Damaged wiring or a dirty connector can inhibit the signal from making it to the computer. Inspect/test/clean/repair wiring or connectors as necessary.
If the CPS/CKP is failed sometimes the OBD-II trouble code reader cannot make a connection to the ECU/computer or cannot read Check Engine Light/MIL codes because the CPS/CKP has failed. Disconnect the code reader, disconnect the CPS/CKP wire connector, and reconnect the code reader. If the code reader establishes contact with the ECU and scans, your CPS/CKP is failed and needs to be replaced.
Crank Position Sensors can have intermittent “thermal failure”. This means that the CPS/CKP fails when the engine gets hot, but works again (and will test as “good”) when it cools back down.
Diagnostic steps to confirm the CPS is the cause of your no-start
1) You should be able to verify a bad cps, by unplugging it, and turning the ignition key to on. If the voltage gauge and/or the fuel gauge now display correctly and/or the No-Bus is gone, replace the CPS.
2) If the CEL does not come on when the key is turned to the RUN position... then the CPS/CKP is bad.
3) Unplugging and reconnecting the CPS sensor where it connect to the main harness near the back of the intake manifold usually resets the ECU and if the jeep fires right up after doing this you can bet that the CPS is faulty and needs to be replaced.
The 2000 and 2001 will have the CPS in the same location on the bell housing, but the wire connector is near the Transfer Case, not as shown in the diagram below. Simply follow the wire from the sensor to the connector.
CPS Testing
Crankshaft Position Sensor Connector (CPS/CKP)
TESTING PROCEDURE 1991 – 2001 4.0L H.O. engines
1. Near the rear of intake manifold, disconnect sensor pigtail harness connector from main wiring harness.
2. Place an ohmmeter across terminals B and C (See Image). Ohmmeter should be set to 1K-to-1OK scale for this test.
3. The meter reading should be open (infinite resistance). Replace sensor if a low resistance is indicated.
TESTING PROCECURE for 1987 – 1990 4.0 L engines
Test # 1 - Get a volt/ohm meter and set it to read 0 - 500 ohms. Unplug the CPS and measure across the CPS connector's A & B leads. Your meter should show a CPS resistance of between 125 – 275 Ohms. . If the CPS is out of that range by much, replace it.
Test # 2 - You'll need a helper for this one. Set the volt/ohm meter to read 0 - 5 AC volts or the closest AC Volts scale your meter has to this range. Measure across the CPS leads for voltage generated as your helper cranks the engine. (The engine can't fire up without the CPS connected but watch for moving parts just the same!) The meter should show .5 - .8 VAC when cranking. (That's between 1/2 and 1 volt AC.) If it's below .5vac, replace it.
CJ7-Tim is offline
post #4 of 6 Old 10-08-2011, 10:26 AM
RamboPants
1987 XJ Cherokee
Mine did that but its an 87 I changed the MAP sensor and that took care of it.
RamboPants is offline
post #5 of 6 Old 10-08-2011, 10:32 AM
tjwalker
It's the crank sensor!
tjwalker's Avatar
Crank sensor is the primary suspect here.
99 Cherokee, 4.0 AW4, NP242
Past Jeeps: 49 Willys, 81 Scrambler, 88 Comanche
Without "data", all you have is an opinion!
tjwalker is offline
post #6 of 6 Old 10-10-2011, 07:44 PM Thread Starter
pjavan
Holy !!! CJ7-Tim, thanks for the detailed post. I will follow your troubleshooting steps. Thanks a ton for that detailed message!!!
pjavan is offline
Air shuts off randomly bwoo90 XJ Cherokee Technical Forum 1 03-23-2011 05:37 PM
engine idels high, and sometimes shuts off davrob9 MJ Comanche Technical Forum 1 06-14-2008 08:23 PM
Engine Shuts off after warms up nimblemotors XJ Cherokee Technical Forum 7 02-01-2008 09:30 PM
Engine shuts off when i stop. myth assassin XJ Cherokee Technical Forum 32 07-23-2006 04:08 PM
Engine shuts down Hottstuff XJ Cherokee Technical Forum 2 08-19-2005 02:33 PM
