Engine Removal from a 2000 Cherokee Sport - JeepForum.com
post #1 of 17 Old 08-05-2013, 09:57 AM Thread Starter
Alwayshopeful
PLEASE HELP!
Pulling/Removing 2000 Cherokee XJ Engine for Swap/Replace/Trade
My XJ Sport has a donor engine from another 2000 Cherokee XJ but we are having a terrible time removing the dead/original engine.
Please we are running into issues involving the loosening of nuts/bolts that are holding the engine to the vehicle inside wall. Specifically the nut within the yellow ellipse.
Please is there a special tool to and/or method to remove just the engine so that a donor engine can be dropped in and attached to the transmission?
Thank you so much for your helpful insight.
Alwayshopeful is offline
post #2 of 17 Old 08-05-2013, 11:30 AM
jeepkid03
Winning
jeepkid03's Avatar
It is hard to tell from the picture, but that looks like a bolt on the firewall. To remove the engine you have to unbolt it from the motor mounts, and separate it from the transmission. There are two E12 torx bolts on the top that are often a pain to get at, but those are on the transmission bellhousing, not the firewall.
-Josh
My 0331 Head Swap How-To Thread:
Build Thread:
jeepkid03 is offline
post #3 of 17 Old 08-05-2013, 07:51 PM
Kevin108
That's the bolt for the ground strap, right?
My build thread has pics again. http://www.jeepforum.com/forum/f177/kevin108s-2000-xj-build-867428/
Kevin108 is offline
post #4 of 17 Old 08-05-2013, 08:14 PM
79chiefs
1988 XJ Cherokee
What was wrong that you are changing the engine??? Could you just have a cracked head like most other 00-01 XJ's? That is for a ground strap.
99WJ Laredo I6-A 2wd
88XJ-Building on a budget.
95 E34 540i-DD
79chiefs is offline
post #5 of 17 Old 08-06-2013, 06:41 AM
Kevin108
I don't want to discourage you but if you're having trouble undoing that bolt for the ground strap, you may not be up to this project.
Kevin108 is offline
post #6 of 17 Old 08-06-2013, 07:08 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Well stated Kevin, and very true.
If you own a Renix Jeep, you'll want to check this out.
An index to over 30 write-ups can be found in the link below
My Jeep Technical Photos
cruiser54 is offline
post #7 of 17 Old 08-07-2013, 07:14 AM Thread Starter
Alwayshopeful
Thank you jeepkid03.
post #8 of 17 Old 08-07-2013, 08:00 PM
1CleanTJ
1CleanTJ's Avatar
that bolt seems pretty easy to get too, you wouldnt need to remove it anyways, just remove the ground strap on motor.
heres a really good tip, youll need to unbolt the transmission from the motor. remove the 2 bolts that are on top (the really hard to get to ones) FIRST otherwise you'll have a ton of tension on them and they will be much harder to loosen.
another tip. once you have the engine hoist attached to the engine, unbolt the motor mounts and let the engine drop down a few inches, makes accessing those bolts much easier, unless you want to connect 3-4ft of extensions togethr and get it from below
Removing the front end makes getting the engine out easier and really doesnt add that much more time.
<-- CLICK !!! AND SHARE
1CleanTJ is offline
post #9 of 17 Old 08-08-2013, 07:13 AM
CCKen
CCKen's Avatar
Originally Posted by Alwayshopeful View Post
PLEASE HELP!
That nut you've circled is one of five that hold the HVAC Unit (under the dash) to the firewall.
Sometimes it's easier to remove the head to get at the top two transmission to engine block Torx head bolts. Otherwise you will need a E12 Torx socket and long extension(s) to come up from the bottom of the vehicle to reach the bolts, having a helper guide the socket on to the bolt heads.
This thread, among others on this forum, discusses the top bolts:
http://www.cherokeeforum.com/f2/bell...-bolts-175825/
CCKen is offline
post #10 of 17 Old 08-09-2013, 05:36 PM
jeepkid03
Winning
jeepkid03's Avatar
No problem. Let me know if you have any questions.
-Josh
Build Thread:
post #11 of 17 Old 08-09-2013, 07:26 PM
Maltesian
When I saw that picture with the wooden posts and chain pulling out the engine all outside, I smiled. A real jeeper, rock on like a true back yard mechanic. Hope it all works out for ya and have all that hard work pay off.
Maltesian is offline
post #12 of 17 Old 08-09-2013, 07:49 PM
79chiefs
1988 XJ Cherokee
Thats the only way to do it. You appreciate the jeep more cause you're in it hopefully with ac and not in the rain trying to get it done so you have your DD back before work monday morning.
95 E34 540i-DD
79chiefs is offline
post #13 of 17 Old 08-09-2013, 08:12 PM
Maltesian
Gotta do what u gotta do
post #14 of 17 Old 08-11-2013, 07:52 PM
1CleanTJ
1CleanTJ's Avatar
*******[/PHP]
Thanks 2.5ton chain hoist and home built frame worked great, comes apart pretty quickly as well. you dont need alot of fancy tools to work on a vehicle, just need ingenuity and hand tools for the most part.
i have access to a shop but at the time this was a cherokee i picked up with a blown motor as a project and worked on it at the house after my usual job. pulled motors out of both jeeps, rebuilt the donor motor, swapped over the coil pack system ( using older block) and painted it all up before sliding it into the 01 cherokee.
theres been countless times ive fixed vehicles in parking lots or in the rain, in the snow etc. its a very good skill to know, tow's and repair bills at shops get expensive
this is my lovely work area during winter repairs. A nice hot fire right behind me
1CleanTJ is offline
post #15 of 17 Old 08-11-2013, 08:16 PM
Maltesian
Originally Posted by 1CleanTJ View Post
*******[/PHP]
Nice, I prize anyone's ability to pull of something using nothing but basic tools and there mind. Yes. It does help to have the proper tools for the task at hand, but there's always usually an alternative. Might require more work, but it will do the job.
I really like the idea of someone working on things themselves and not relying on other people especially when it comes to something we depend on alot, which Is why I bought a jeep. Again, lol.
I actually made it a goal of mind to just learn as much as I can about maintaining a jeep Cherokee, I want to avoid,bills, asking for rides everyday to work, having to call and see whats going on, and worst of all going back time and time because its not fixed....that sucks *** my-friends.
