Engine races - JeepForum.com
post #1 of 2 Old 08-17-2002, 01:04 PM Thread Starter
ski-trux
Question Engine races
Hi guys, I'm a 1st timer here and I have a little problem that I hope you can help me with. Sometimes while I'm driving, at any speed, the engine will start to race at about 2000rpm. If I try to kick it down with the accelorator, it just races faster. I have to throw it into neutral to stop the vehicle and then of course it just races faster, about 3000 rpm. I have to turn off the ignition and restart to get back to normal idle speed. Any clues?
It's an 88 Cherokee with a 242c.i.d. straight six and multi-point fuel injection.
88 cherokee limited
ski-trux is offline
post #2 of 2 Old 08-18-2002, 11:31 AM
arpy
Sounds like a problem with the throttle position sensor (TPS), check for moisture, corrosion or damage to the connector/wiring, or you might need a new TPS.
arpy is offline
Engine Trouble - Rough engine, temp question fyurien XJ Cherokee Technical Forum 0 08-11-2008 07:56 PM
High Performance engine options? Stroker? Engine swap? fast64 XJ Cherokee Technical Forum 1 04-27-2007 04:34 AM
XJ running the SCORE races... prior2 XJ Cherokee Technical Forum 1 07-31-2005 11:30 PM
Engine hesitation, Loss of power and Check engine light iflyabeech XJ Cherokee Technical Forum 37 04-14-2005 08:33 AM
Engine Races during Startup spieg16 XJ Cherokee Technical Forum 4 10-07-2004 07:07 PM
