engine opinions please - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > engine opinions please
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineRockridge 4WD IS Taking Zone Offroad Suspension Lift Kits Northridge4x4 - Superchip Flashcal In Stock
Unread 11-06-2005, 08:05 PM   #1
jeepcher4x4
I need help my engine has a metal tapping sound. I was told it was a wrist pin by a mechanic. My parents bought me a truck and we have to keep the jeep cause insurance. I am in an offroad club and its going to be trail rig. What should i do as far as an engine and how much $$ my options r gna cost. I have a job. I am only 16. Opinions please
98 tj 6 inches of lift ........
88 xj 4 inches of lift RE and skyjacker combonation jks quick disco's surco roof rack etc...... pretty good for a 16 year old I have done every mod to current date
jeepcher4x4 is offline   Reply With Quote
Unread 11-07-2005, 04:49 AM   #2
JoBo
The 4.0 I6 engines are nosey in general but if you have the auto trans the most often cause is the flex plate bolts loosening. Easy cheap fix, use the search function. If it's the engine then it's likely piston slap and that can be helped with a can of RESTORE at every oil change
[B]JoBo[/B]
Columbus, Ohio USA
2006 KJ CRD [COLOR="Blue"]Atlantic Blue Pearl Coat[/COLOR][COLOR="Black"] Limited[/COLOR]
2000 Cherokee Classic with factory 16" wheels
JoBo is offline   Reply With Quote
Unread 11-07-2005, 10:15 AM   #3
XJ4oh
1997 XJ Cherokee
My vote is either for a bad lifter, loose rocker arm, or the flex plate bolts being loose. If you have something else to drive, and this will be a trail rig only.. then either buy a used motor now and drive this one till it blows, or pull the engine yourself and tear it down, and teach yourself how to re-build it.
'97 XJ... 4.0 4x4 AW4.
2" budget boost w/t-case drop.
31x10.5 Cooper Discoverer ST's on 15x7 Cragar Soft 8's.
Intake, Ported TB, TB spacer, Super 40 Flowmaster.
Baja Aux. Lighting.
Green Jeep Club #185, Nowhere to Wheel Jeep Club member #1
XJ4oh is offline   Reply With Quote
Unread 11-07-2005, 11:13 AM   #4
88Mud
My piston slap is most noticeable at or near idle and/or when it's cold. I picked up another knock, that got worse as the RPM's went up, turned out to be mostly the connecting rod bearings, I checked them with plasti gauge and they were at the outside allowable measurement. If you check the clearance on the connecting rod bearings, check the top bearing, as this is the one that wears the most.
My top end valve train rattles pretty good but it never seemed to hurt much.
Changing the connecting rod bearings, isn't really that much of a job. And can be done with the motor still in the Jeep.
I use a piece of plastic tubing held to my ear, to localize the sound. Listing in the oil filler hole might tell you if it's in the top.
I've never heard anybody else mention wrist pins as a trouble spot. But heck anything is possible.
88Mud is offline   Reply With Quote
