Engine misfire - JeepForum.com
post #1 of 11 Old 12-12-2012, 05:07 PM Thread Starter
rjlamber
1995 XJ Cherokee
Engine misfire
Hi
I just finished replacing my distributor cap, rotor, ignition wires, and all six spark plugs. After I wrapped everything up, I started the engine and I have a misfire. The engine shakes and the exhaust stutters. I'm confident that all wires are going to the proper nodes (I removed them one at a time, replaced the plug, replaced the wire, on to the next one) and that all of the connections are secure. I called my local jeep dealer and he said it could be a problem with the brand of spark plug I used (autolite platinum). The previous plugs were bosch platinum, and there was no misfire, however it did have a rough idle and tried to stall at stoplights. Any thoughts on the cause of the misfire? Also, I tried addressing the stall issue by cleaning the throttle body and the IAC, it helped some, but not entirely.
Thanks in advance for any advice.
rjlamber is offline
post #2 of 11 Old 12-12-2012, 05:36 PM
tjwalker
It's the crank sensor!
tjwalker's Avatar
The big question here is this. Did you have a misfire BEFORE you did the work?
If the answer is no, you must look at "cause and effect" principle, which means that something you installed introduced that misfire.
For a 95, I prefer Champion Copper plugs, but I do not believe that the plugs (if properly gapped to .035, did you verify this on each plug before installing?) would be the cause.
Do you still have your old parts? If you do and if you didn't have a misfire before, I would start with replacing one old part at a time until you find the problem.
Keep us updated! This is not going to be hard to find.
99 Cherokee, 4.0 AW4, NP242
Past Jeeps: 49 Willys, 81 Scrambler, 88 Comanche
Without "data", all you have is an opinion!
tjwalker is offline
post #3 of 11 Old 12-12-2012, 05:53 PM Thread Starter
rjlamber
1995 XJ Cherokee
The misfire occurred after the work, so I obviously messed something up. I was going to get a plug gapper while I was picking up the plugs but the guy at autozone said I wouldn't have to gap these particular plugs. I'll try putting the old parts back in and see what I come up with.
rjlamber is offline
post #4 of 11 Old 12-12-2012, 05:57 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Never take technicaladvice from an AZ counterperson.
If you own a Renix Jeep, you'll want to check this out.
An index to over 30 write-ups can be found in the link below
My Jeep Technical Photos
cruiser54 is offline
post #5 of 11 Old 12-12-2012, 05:59 PM
tjwalker
tjwalker's Avatar
Please everyone. Verify the gap on every single spark plug you install, whether it is for your XJ, your lawn mower, or for your cocktail blender.
Never trust gap out of the box. I cannot tell you how many plugs I have had to gap out of the box because gap is way off.
Gap your plugs.
tjwalker is offline
post #6 of 11 Old 12-12-2012, 06:01 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Post up some photos of our cocktail blender, please.
post #7 of 11 Old 12-12-2012, 06:10 PM
buildin1XJ
I'm pretty sure TJ has a 4.0 powered cocktail blender,So misfires can not be tolerated.
buildin1XJ is offline
post #8 of 11 Old 12-12-2012, 06:13 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
I'm thinking you could pull 2 plug wires and it would shake that martini rather than blend it.
post #9 of 11 Old 12-12-2012, 06:17 PM
tjwalker
tjwalker's Avatar
Guys.....I actually have a neighbor with a single cylinder blender.
Daiquiri Whacker! Homelite weed whacker engine powers it. It is so cool! Great for happy hour! Check it out....
http://www.gasblender.com/
$308 (overpriced to be sure) and you can be the life of the party. Or strip down your old weed whacker and build your own!
tjwalker is offline
post #10 of 11 Old 12-12-2012, 06:33 PM
buildin1XJ
Thats AWSOME TJ I have several Shindawia engines I could use to build that.Ibet I would be the life of the party on top of a mountain here in TN.
post #11 of 11 Old 12-12-2012, 06:55 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Do you need to shake up moonshine?
idle , misfire , shake , spark plug
