Quantcast Engine hesitation, Loss of power and Check engine light - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > Engine hesitation, Loss of power and Check engine light
Old 04-03-2005, 11:48 AM   #1
iflyabeech
I just upgraded to a 1999 Cherokee 4.0 4x4 5 speed . . . I was accellerating on the highway, going through 55 MPH in 4th gear and the Jeep kinda hesitated, and the check engine light came on. It seemed to have lost some power. . . Would not go over 70MPH. . .I stopped, then accellerated again and accelleration felt normal. . . and Jeep had no problem getting over 70. . .I am going to try to get the trouble codes fromt he Jeep. Any one have any clues as to what my problem might be?
Thanks!
1999 XJ Cherokee SE 4dr 4x4
4.0L I6, AX15 5-Speed Tranny, NP231, Dana 30 high pinion Front, Chrysler 8.25 Rear, 3.07 gears, Quadretec HD leaf springs
http://www.thirdcoastoutdoors.com
iflyabeech is offline   Reply With Quote
Old 04-03-2005, 12:46 PM   #2
JeepCrazyKid
way easier to get your codes first and see where to go from there. Could be lots of things.
JeepCrazyKid is offline   Reply With Quote
Old 04-03-2005, 01:40 PM   #3
iflyabeech
OK, I we had already unhooked the battery and reset the computer before I got the codes. . .I drove around today and tried to get the problem to repeat itself today bith no luck. . .I have to take it on a road trip this week and would like to figure out the problem beforehand. . . Any ideas?
Thanks
Old 04-03-2005, 04:54 PM   #4
iflyabeech
Ok, I went out and drove the Jeep again. I did not get a light this time but it does not accellerate properly and it just seems to have a lack of power. It seems to be worse after it has warmed up. It seems to accellerate fine in the bottom part of a gear, but after revving to a higher RPM, it seems to be limited. It almost feels like you have more power when you upshift. . .I am thinking it could be fuel injectors, fuel pump, Cat. converter, or fuel filter. . . Could it be ignition related? Please help! Thanks!
Old 04-03-2005, 10:29 PM   #5
iflyabeech
Come on guys, I have been checking this often today and noone has replied. . .Someone has to have had this happen to them before. . . Please help!
Old 04-04-2005, 04:17 AM   #6
Alexia
Fuel pump, oxygen sensors. You should hear the fuel pump buzz when your put the key to On/Run. Check your spark plugs. Basically go over all the usual maintenence items.
2004 Jeep Wrangler Unlimited, Automatic
RC 2.5" Lift - RC 2.5" Rear Track Bar Bracket - JKS 1.25" Body Lift - JKS Front Disconnects - JKS 1" Budget Motor Mount Lift - Spidertrax 1.25" Spacers -
Power Door Locks with Keyless Entry
Build Project Thread
Rocker Guard Comparison Chart - Final Differential Gear Ratios - Oxygen Sensor FAQ
Alexia is offline   Reply With Quote
Old 04-04-2005, 04:24 AM   #7
nwfxjguy
Similar thing happened to me several years back. I have 94 XJ, and it would hesitate and cut out, but always start. Had it in the dealer several times, but no resolution. They finally hooked up the computer to try and capture any codes, but it wouldn't fail. I took a look at the rotor and cap and noticed it was corroded. I changed them and all was fine. At the time it was less than a year old, so I guess no one thought it could be the cap and rotor.... The difference is your getting the check engine light. I don't know if that would cause the check engine light to come on in the newer models, but that is what I've got to offer...
nwfxjguy is offline   Reply With Quote
Old 04-04-2005, 04:27 AM   #8
Alexia
90% of the time the check engine light is oxygen sensor goind bad. That doesn't usually cause this problem though.
Old 04-04-2005, 05:16 AM   #9
lbsnowryder
One notch above Redneck!!
lbsnowryder's Avatar
I had this happen and even paid to have it ran on a diagnostic. Unfortunatly it wouldn't do it in Nuetral. It ended up being a line on the fuel pump. It's hard to say cause your's is a 99. That is only a guess and hope it puts you in the right direction.
LB
_____________________________________
I own a Jeep, it's red and has big tires
Radical Pictures
lbsnowryder is offline   Reply With Quote
Old 04-04-2005, 08:41 AM   #10
iflyabeech
Thanks for the responses. . . . I will have it checked out today. . . Now it is not giving me a check engine light!
Old 04-04-2005, 09:08 AM   #11
badron
OK, I say start over with the basics. You need a can of contact cleaner. Go over every plug under the hood. check every vacuum line under the hood. Check or change filters etc. Check to see all grounds are clean and snug.
A 99 how many miles on the plugs. They could be getting weak but still test good on them F***edup computers. Even if new pull them. Check the plugs for anything unusual. Plugs are you eyes inside the engine. Lean to read them. They can tell you so much. Check plug wires cap coil etc. Do a night time under the hood peak. Watch for sparks.
Got a vacuum gauge? Hook her up. At idle it should read about 25 or so. It should be steady as a rock. The key here is steady. Any change of 2 LB or more may mean problems.
Got a fuel presser gauge. Check that out. When I say gauge I mean a REAL gauge not the computer readout.
I ***** about computers a LOT. It not the computer fault. Most shop just want to hook you up to one and if that don't find a problem they want to give up. They just don't want to spend the time digging in and finding what's wrong. They want you to drive it till it completely goes out. Then they can find it.
The best testing gear you got is between your ears. Use it.
R Robinson
badron is offline   Reply With Quote
Old 04-04-2005, 09:09 AM   #12
JeepCrazyKid
Still check for codes anyway. You don't need a check engine light for it to throw a code.
Jon
'06 WK
'03 TJ
'98 XJ
Old 04-04-2005, 09:13 AM   #13
badron
Sorry double post can't delete
R Robinson
Old 04-04-2005, 09:46 AM   #14
BeachinXJ
Resident McGeek
BeachinXJ's Avatar
Read The Friggen Codes!
YOU need to get the codes pulled!
Kyle - I tag stuff®
2000 Jeep XJ - Chopped / Locked
1997 Jeep XJ - Daily Driver
2003 Dodge Ram 2500 CTD - 6-speed, 4" MBRP Turbo Back Exhaust
Join the XJ Owners Club | Download the iMarn® iPhone App!
SIRA 4x4 Offroad Association
Rule #1 - No talking about the weather!
Homepage | Jeepspace Group|Twitter!|Facebook
BeachinXJ is offline   Reply With Quote
Old 04-04-2005, 11:00 AM   #15
iflyabeech
I tried getting the codes via the "hold the odometer button down and reset the key switch 3 times and all it did was count and flicker the gauges. . .no codes!
It drives wonderfully when it is cold, but after it warms up it just won't go! All I could get in 4th gear was 72 MPH and 75 MPH in 5th. . . .Yes, it is a 4.0!
I am thinking it could be the cat. . .but I don't hear much hissing!
Glock Forum
