Engine hesitates after towing old trailer - JeepForum.com
post #1 of 3 Old 07-02-2007, 10:35 AM Thread Starter
mhjo
I barrowed an old trailer today, and after driving with it I noticed hesitation from the engine. later the engine just stopped (on the freeway!). It seed that there something wrong with fuel supply. I managed to get home by holding minimum 1500 rpm and using accelerator/brake pedal actively.
This same thing happened a while ago the last time I barrowed the. same trailer. However, this time the problem continued after I disconnected the trailer.
I tried to disconnect battery terminal for an hour in order to reset the computer, but I noticed little improvement.
What caused this, and how to I fix this isssue?
1996 4.0 Country, K/N, MSD ignition, Dynomax VT, 63mm TB
mhjo is offline
post #2 of 3 Old 07-09-2007, 02:12 PM
turtle13572
Not sure if it is the same, I found two problems after towing a 4k trailer. One, my fuel pressure regulator was leaking fuel, fixed with new orings and the second was a clogged cat. Dont think it would cause your motor to die but... Hope this helps -Turtle
turtle13572 is offline
post #3 of 3 Old 07-09-2007, 04:59 PM
Green97Cherokee
How does it act with a new trailer and is it an auto or manual?
Green97Cherokee is offline
Cherokee hesitates and engine backfires/pops PTCjeeper XJ Cherokee Technical Forum 18 07-20-2009 07:57 AM
Engine stumbles and hesitates and wont rev. tarvis XJ Cherokee Technical Forum 3 05-22-2007 05:16 PM
My engine idles but hesitates and stumbles. tarvis XJ Cherokee Technical Forum 3 05-21-2007 03:26 PM
engine hesitates when i give it a quick punch to the throttle... rustybottoms MJ Comanche Technical Forum 4 04-28-2005 09:40 AM
Engine cranks and hesitates before turning over KZOO XJ Cherokee Technical Forum 4 04-07-2005 10:24 AM
