Engine/head replacement - opinions sought - JeepForum.com
 1Likes
  • 1 Post By CJ7-Tim
post #1 of 7 Old 07-13-2017, 09:40 AM Thread Starter
Riley/MN
Xj Engine/head replacement - opinions sought
So I blew the engine in the 98. Pulled the engine from a 93 to rebuild & replace it. It will be a 4.x stroker. I have the choice of three heads to put back on. I don't have the casting codes A friend is trying to sell me a rebuilt/refreshed head with a 89 date code, so I assume from a 90. I have the head from the 93 with a 92 date code, or the head from the 98 with a 97 date in the casting. I assume that what I have is a 2682, a 7120 and a 0630. My current thoughts are to spend the money towards refreshing the 0630 head. Does that sound like the way to go?
Thanks
~Riley
~Riley
TMA MN State Rep
http://www.traditionalmuzzleloadingassociation.com
Riley/MN is offline
post #2 of 7 Old 07-13-2017, 05:09 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
The 7120 and 0630 are this close to being the same. Some people claim that the 7120 will add a few HP. Either way you go, you should be smoothing out any casting boogers, port matching, and polishing.
Riley/MN likes this.
CJ7-Tim is offline
post #3 of 7 Old 07-14-2017, 08:23 AM Thread Starter
Riley/MN
That's what I was thinking too. Thanks
~Riley
TMA MN State Rep
Riley/MN is offline
post #4 of 7 Old 07-17-2017, 02:30 PM Thread Starter
Riley/MN
Okay, discovered something else. My friend's head that has been redone has some of the coolant passages sealed off. Would this be an advantage? I am thinking he probably did so to put it on a 4.2 block...
~Riley
TMA MN State Rep
Riley/MN is offline
post #5 of 7 Old 07-17-2017, 03:48 PM
CJ7-Tim
CJ7-Tim's Avatar
I think that would make it a no-go for an XJ, unless you can get all the passages open again.
CJ7-Tim is offline
post #6 of 7 Old 07-18-2017, 08:16 AM Thread Starter
Riley/MN
Yeah, I am just not sure why it was done. 4.2 block is the only thing I could come up with...
~Riley
TMA MN State Rep
Riley/MN is offline
post #7 of 7 Old 07-18-2017, 08:22 AM
RedJeepster1
Low and Slow
RedJeepster1's Avatar
Probably so it could be put on a 4.2 block, that's a pretty common thing with the FI swap on the older engines.
88 YJ with a 4.6l stroker, AX-15, NP231, 2.5" lift, 4.10's and 33's
2000 Red XJ w/ 350k+, AW4, NP231, Locked Rear, HD Crown Leafs, trimmed to fit 33's, soon to be a donor
2000 Silver XJ, Drivetrain from the Red XJ, Stiffened, IRO leafs, RE coils, custom 3 link, WJ knuckles, 35's <=== In the works
RedJeepster1 is offline
