Engine firewall? - JeepForum.com
post #1 of 5 Old 08-12-2002, 07:58 PM Thread Starter
GPTH1NG
GPTH1NG's Avatar
Engine firewall?
I just noticed that the under-hood of my '01 doesn't have any firewalling on it. I know that the older Jeeps did (I've seen it on several '89 - '92's) and was wondering - is there a good reason for this? I'm going to buy some, I just don't want to cause other problems.
01 Cherokee Sport
Amber Fire
ORANGE Jeep Club Member #3
04 Wrangler X
GPTH1NG is offline
post #2 of 5 Old 08-12-2002, 10:43 PM
arpy
Um, the firewall is the sheetmetal separating the engine and passenger compartments. I guess you are talking about some kind of insulation? There is none on my 88.
arpy is offline
post #3 of 5 Old 08-13-2002, 01:55 PM
EricsXJ
The Post man
EricsXJ's Avatar
hood insulation
Theres no hood insulation on my 2000 and I prefer that its not there. It'll make it that much easier when I install hood vents. Why do you want to buy it? It may make the engine run hotter, and if you have any problems, it could void your warranty.
Eric
2000 XJ "PROJECT RUBICON" 3-link front / 4-link rear / coilovers / running 37's on Dana 60s
My website -
EricsXJ is offline
post #4 of 5 Old 08-13-2002, 02:03 PM Thread Starter
GPTH1NG
GPTH1NG's Avatar
Well, I've seen some older vehicles without it, and their hoods are all faded (from engine heat, I assume, since it doesn't affect the rest of the vehicle.) I plan on keeping mine for as long as possible, and I'd rather not have that happen.
01 Cherokee Sport
Amber Fire
04 Wrangler X
GPTH1NG is offline
post #5 of 5 Old 08-13-2002, 03:25 PM
glenzx
glenzx's Avatar
3 reasons paint is faded/peeled:
1) front end repair and subsequently poor paint job - seen that a million times...
2) rarely (if ever) washed & waxed...check the roof when you do see a hood all faded, typically all the flat surfaces will be faded as well (especially here in the southwest!)
3) engine fire! in which case that dang insulation isn't gonna help.
Incidentally, that insulation on the firewall and the hood in some cars is strictly for noise protection, not any kind of heat, and, as Eric mentioned, will only INCREASE the engine compartment temperature, which is not good unless its in Alaska...
glenzx is offline
Water Leak Behind Engine by Firewall neutrolizr XJ Cherokee Technical Forum 8 06-01-2009 03:59 PM
How to unplug engine wiring harness from firewall? chondamx XJ Cherokee Technical Forum 2 09-05-2008 08:55 PM
How do I get through the firewall? mopar3389 XJ Cherokee Technical Forum 6 02-25-2007 01:01 PM
whats the thingy on the firewall on the left of hte engine? Xride XJ Cherokee Technical Forum 8 09-10-2004 04:02 PM
through the firewall 97cherokee XJ Cherokee Technical Forum 3 01-04-2003 08:18 AM
