Engine down on power when engine cold - JeepForum.com
post #1 of 7 Old 03-08-2011, 07:38 AM Thread Starter
98jeepxjlimited
sometimes when the engine is still cold the jeep has almost no power.
it will be fine going down the road, right after startup, then randomly when foot is on the gas it will be as if i just took my foot off the gas, then i get a surge of power.
it happens once in a while. and never happens when warm..
what could this be? i installed a new cap rotor and plugs less than 10k ago. there are no vac leaks.
98jeepxjlimited is offline
post #2 of 7 Old 03-08-2011, 11:33 AM Thread Starter
98jeepxjlimited
"its 1:32pm and im in a boring class" bump
post #3 of 7 Old 03-08-2011, 01:05 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Test the Throttle Position Sensor.
TPS TEST
You should have 5 volts going into the Throttle Position Sensor (TPS). It is best to use an analog meter (not digital) to see if the transition from idle to WOT is smooth with no dead spots. With your meter set for volts, put the black probe on a good ground like your negative battery terminal. With the key on, engine not running, test with the red probe of your meter (install a paper clip into the back of the plug of the TPS) to see which wire has the 5 volts. At idle, TPS output voltage should be greater than .26 volts but less than .95 volts. Move the throttle and look for smooth meter response up to the 4.49 at WOT. The other wire will be the ground and should show no voltage.
Perform the test procedure again and wiggle and/or tap on the TPS while you watch the meter. If you notice any flat spots or abrupt changes in the meter readings, replace the TPS.
The TPS is sensitive to heat, moisture, and vibration, leading to the failure of some units. The sensor is a sealed unit and cannot be repaired only replaced. A TPS may fail gradually leading to a number of symptoms which can include one or more of the following:
-Poor idle control: The TPS is used by the ECU to determine if the throttle is closed and the car should be using the Idle Air Control Valve exclusively for idle control. A fault TPS sensor can confuse the ECU causing the idle to be erratic or "hunting".
- High Idle Speed: The TPS may report faulty values causing the engine idle speed to be increased above normal. This is normally found in conjunction with a slow engine return to idle speed symptom.
-Slow engine return to idle: A failing TPS can report the minimum throttle position values incorrectly which can stop the engine entering idle mode when the throttle is closed. Normally when the throttle is closed the engine fuel injectors will be deactivated until a defined engine RPM speed is reached and the engine brought smoothly to idle speed. When failing, a TPS will not report the throttle closed and fueling will continue, causing the engine to return to idle very slowly.
-Engine Hesitation on Throttle Application: The TPS is also used by the ECU to determine if the driver has applied the throttle quicker than the Manifold Air Pressure sensor can read. The fueling is adjusted accordingly to cope with the sudden increase in air volume, however a faulty sensor can cause the ECU to ignore this data and the engine will "hesitate" when applying the throttle. In extreme cases with the engine at idle, a sudden application of full throttle can stall the engine.
- Engine Misfire: A faulty TPS can report values outside the acceptable range causing the ECU to incorrectly fuel the engine. This is noticeable as a slight misfire and can trigger the misfire detection software and/or Malfunction Indicator Lamp (MIL) light on the dashboard. Extreme cases can cause excessive misfires resulting in one or more cylinders being shut down to prevent engine and catalytic converter damage.
CJ7-Tim is offline
post #4 of 7 Old 03-08-2011, 07:40 PM Thread Starter
98jeepxjlimited
the TPS is brand new. less than 8,000 miles ..hmm
post #5 of 7 Old 03-09-2011, 02:55 AM
CJ7-Tim
CJ7-Tim's Avatar
Originally Posted by 98jeepxjlimited View Post
the TPS is brand new. less than 8,000 miles .....
Cheap crappy one from IdiotZone, Advance, or a good one from NAPA or JEEP ?
CJ7-Tim is offline
post #6 of 7 Old 03-09-2011, 07:11 AM Thread Starter
98jeepxjlimited
ahahhaha idiot zone. i hate that place i never go there unless its an emergency! its from Napa. i replaced it because the jeep would just rev every gear all the way to the highest shift point, as if i had my foot mashed, but i didn't. it shifts just like the day i installed it (TPS)
post #7 of 7 Old 03-11-2011, 07:39 PM Thread Starter
98jeepxjlimited
Aux fan is running when engine is cold? Brighton Jeeper XJ Cherokee Technical Forum 5 03-13-2010 10:06 AM
Chirp from engine bay when cold, and only sometimes? Xride XJ Cherokee Technical Forum 2 02-13-2006 01:51 PM
Engine hesitation, Loss of power and Check engine light iflyabeech XJ Cherokee Technical Forum 37 04-14-2005 08:33 AM
Engine knocking only when cold jeep-noob XJ Cherokee Technical Forum 13 01-31-2005 11:44 PM
another cold running engine DeathCrush XJ Cherokee Technical Forum 2 05-09-2004 11:51 AM
