Engine dies while at stop light - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > Engine dies while at stop light
Rough Country Deals at JeepHut.comIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineEngo winches available at www.rockridge4wd.com! Free shipp
Unread 07-26-2007, 11:28 PM   #1
johnflores
I have had a hesitation problem on acceleration with my 1987 XJ. It only occurs when I accelerate from a full stop, like at a stop light. Up to now it has only been a slight hesitation and then things go on as normal. Recently, however, the car has started dying at stop lights. I hear the hesitation and then 'dead'.
I have replaced the fuel filter and done a complete tune up but, the problem is getting worse. Could it be the fuel injectors? I also replaced the CAT and exhaust.
Thanks for your help.
johnflores is offline   Reply With Quote
Unread 07-26-2007, 11:30 PM   #2
balloo93
Little Red Menace
balloo93's Avatar
1993 XJ Cherokee
Unplug the EGR vac line and plug it. If the hesitation stops at lights, replace the EGR valve.
93 Sport
Beer is proof that God loves us and wants us to be happy............Ben Franklin
Specs in Profile.
http://www.cardomain.com/ride/325707/1
http://www.cardomain.com/ride/2406854/1
balloo93 is offline   Reply With Quote
Unread 07-27-2007, 10:48 PM   #3
RamboPants
1987 XJ Cherokee
Man i am having the exact same problem with my 87. I have new plugs wires, cap,button, TPS fuel filter, Air filter and was gonna replace my Cat but not sure now. Does your's also start right back up after its quits?
RamboPants is offline   Reply With Quote
Unread 07-28-2007, 08:05 AM   #4
mk20rockeye
1992 XJ Cherokee
mine was starting to do that a few months ago.......i took the idle air control motor out cleaned it up and clean up the throttle body housing. it has been working fine since. try it.....i was hesitant, but it worked for me.
Your lack of planning does not constitute an emergency on my part
1992 XJ Laredo 4.0L, AW4, NP242, 3.5" RE super ride
Definity Dakota 31x10.50 MT's Cragar soft 8
Marine Corps Jeep club member #9
mk20rockeye is offline   Reply With Quote
Unread 07-28-2007, 10:06 AM   #5
dogboy
The fuel pump could be in need of replacement also..They are in the tank of course..The tank does not have to be removed...The pumps have a sock like filter on the pickup tube that can get gunked up also..Especially on older XJ's that have sat...If its the fuel pump you will probably notice it the most when you mash the gas or go for passing gear which is a sign of not getting enough fuel...It will stumble , hesitate or backfire slightly even..
1990 XJ, 4x4, 2" Budget Boost 30x9.5-15
222,000 miles and counting..Update.. 250,000 and counting. Still no major repairs..
1989 XJ, 4x4, 2" BB, Wagoneer Limited (Woody)
79,500 miles.
dogboy is offline   Reply With Quote
Unread 07-28-2007, 05:51 PM   #6
RamboPants
1987 XJ Cherokee
So if the strainer is clogged would it be better just to buy a new one?
Unread 07-28-2007, 06:09 PM   #7
tangofox007
I had the same problem. A new TPS solved it for me. If your TPS is original, it's a pretty safe bet that it's a bit "tired."
tangofox007 is offline   Reply With Quote
