Engine cranks no start ,but push starts - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > XJ Cherokee Technical Forum > Engine cranks no start ,but push starts
The Original 3/8" Ruffstuff Diff Cover!Ruffstuff Axle Simple Swap Kit!The Ruffstuff NOT Universal 4 Link Kit!
Unread 01-27-2010, 12:45 AM   #1
fishman28
1986 FSJ Cherokee
I have a 1986 Jeep Cherokee 2.8 V6 with HEI ignition. I have a weird problem. The Jeep randomly doesn't start and the tach shows to activity, however, it starts every time when I push/bump start it. I have talk to numerous people and been battling this for three months now. Usually when you push/bump start your car, when you have a battery/starter issues. I can crank the engine forever and the tachometer shows no activity. I physically see the engine turning over. Sometimes the engine will start randomly when I crank it. This has a CA emmissions and no crank or cam sensor. The coil is getting 12 volts when ignition is in the run position and 11.5 when cranking/start position. Any help?
fishman28 is offline   Reply With Quote Quick reply to this message
Unread 01-27-2010, 12:50 AM   #2
robdoggydog1
1970 CJ5
could be your ignition switch closing the circuit in the start position instead of opening it ,but open in the the on position.
robdoggydog1 is offline   Reply With Quote Quick reply to this message
Unread 02-06-2010, 04:30 PM   #3
fishman28
1986 FSJ Cherokee
It was the ignition control module. Hope this helps with anyone with my same symptoms. It didn't competely go out, just randomly.
