engine coolant overflowing - JeepForum.com
post #1 of 7 Old 08-04-2005, 04:34 PM Thread Starter
m_w_m
This is the second time this has happned to me. I tried searching for an hour and came up with nothing. I drove my cherokee 1990 2 dr for about 50km and i parked in a gas station to go buy something and i came out and my coolant bottle overflows and it poors out coolant everywhere! Whats going on?
1990 2 door red cherokee larado
3.5" rubicon express 6030
31" MT's
m_w_m is offline
post #2 of 7 Old 08-04-2005, 04:42 PM
tangofox007
Coolant bottles are prone to cracking. And they warp so that the cap fails to seal completely. And the cap gaskets leak. Or you could have a more serious problem. There is a pressure relief valve in the cap, so it could have been a genuine overheat condition. But I would start by checking the bottle and cap for crack/leaks.
tangofox007 is offline
post #3 of 7 Old 08-04-2005, 04:47 PM Thread Starter
m_w_m
I cant screw the cap on very tight at all i just do it finger tight and when i over tighen it a little bit it comes loose like its striped or something. should i be able to crank it real nice and tight?
31" MT's
m_w_m is offline
post #4 of 7 Old 08-04-2005, 04:47 PM
coppertop71
coppertop71's Avatar
1990 XJ Cherokee
Heres a link for a suggested idea to getting rid of that tank. You can see my pic's and see my solution.
Cherokee America
Mods
2006 Jeep Wrangler X, 4.0 4:11 gears
'90 Cherokee XJ,W/'91 4.0L reman/ 3.5" RE lift, W/31" M/S tires, 4:11 Gears W/Speedo gear change/ Aluminum Coolant Tank
A/C Conversion/Home Built Roof Rack/K&N Box Filter
Derale 15" Rigid Radiator Fan PT# DER-17415, through Summit W/2"X5/8X5/8"" spacer
coppertop71 is offline
post #5 of 7 Old 08-04-2005, 04:58 PM
tangofox007
Yes, the cap should go on fairly tight. But not too tight or the gasket will spread. Sounds like it's time for a new cap and bottle. I just had the same problem on my '88. A new cap/bottle solved the problem. I am now on bottle #4 since new. The first two cracked.
You can find the cap/bottle online for as little as $20 US. Check www.rockauto.com or Ebay.
post #6 of 7 Old 08-04-2005, 05:10 PM Thread Starter
m_w_m
My friends parting out his 88 so ill grab his off him
31" MT's
m_w_m is offline
post #7 of 7 Old 08-04-2005, 05:19 PM Thread Starter
m_w_m
Thanks for all the replys too
31" MT's
m_w_m is offline
Engine Oil in Coolant j.ski1 XJ Cherokee Technical Forum 2 06-05-2007 08:02 AM
Engine coolant compatability? muddy bike XJ Cherokee Technical Forum 7 01-31-2005 11:52 PM
overflowing expansion tank rokclimbertx XJ Cherokee Technical Forum 5 09-08-2004 08:35 PM
Engine Coolant Osteonis XJ Cherokee Technical Forum 6 08-20-2004 12:43 PM
coolant overflowing........... jerryhipp XJ Cherokee Technical Forum 3 10-25-2002 10:01 AM
