Engine Coolant Drain plug...where? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > Engine Coolant Drain plug...where?
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineCHASSIS SAVER™ Rust Preventive Paint Memorial Day Weekend RuffStuff Memorial Day Sale!
Unread 03-19-2009, 05:43 PM   #1
RogueXJ
1997 XJ Cherokee
Ok, I am trying to do a full system flush for my 97' 4.0 L XJ. Already found the radiator drain plug, now I neeed the engine block drain plug...Where is it? Pictures helpful....
Jeep XJ 97' 4.0 I6 60 mm TB Bore,
______________________________________
My Jeep isn't getting LIFTED....its EVOLVING.
RogueXJ is offline   Reply With Quote
Unread 03-19-2009, 05:50 PM   #2
5-90
1988 XJ Cherokee
Look on the driver's side of the block, behind the exhaust manifold. You should see a square recess - this is the drive recess for the plug. It is 5/6" or 8m/m (same thing either way,) and you can make a tool fairly quickly from a cheap hex key (instead of buying a spendy one off of the tool truck.)
I am informed that the plug is threaded 3/8" NPT, and you can therefore secure a replacement at the local hardware store. One thing I plan to do is to put a valve in on an elbow to replace that silly plug...
"recon" (sic - reckon)(tm) "hihgly"(tm) "seceed"(tm)
"Outback AIDS - Alcohol-Induced Dizzy Spells"
5-90 is offline   Reply With Quote
Unread 05-18-2009, 09:51 AM   #3
xj2k
Thanks for the information. I was also looking for the engine coolant drain plug location. Now that I found it, while looking for a tool I realized that my 3/8" square drive was too big and your post, quoted below, I think you meant, 5/16" instead of 5/6".
Originally Posted by 5-90 View Post
...It is 5/6" or 8m/m (same thing either way,) ...
Here's is a pic showing the location of the plug. It's a view looking into the xj from left front. I've taken off a under engine splash guard.
xj2k
xj2k is offline   Reply With Quote
Unread 05-18-2009, 09:56 AM   #4
tjwalker
It's the crank sensor!
tjwalker's Avatar
I personally don't drain the block. As long as coolant is changed somewhat regularly, I don't think it's necessary.
And as for the radiator, I drain it by dropping the lower hose. Easier than getting to the radiator petcock and less chance of snapping it off/leaks.
99 Cherokee, 4.0 AW4, NP242
Past Jeeps: 49 Willys, 81 Scrambler, 88 Comanche
Without "data", all you have is an opinion!
tjwalker is offline   Reply With Quote
Unread 02-18-2011, 11:56 AM   #5
mjonesjr
I know this is an old post, but would this drain location be a good spot for a temp gauge sensor?
mjonesjr is offline   Reply With Quote
