Engine Compatibility - JeepForum.com
post #1 of 2 Old 12-12-2011, 10:06 AM Thread Starter
stinealbert
1989 MJ Comanche
I've been informed by auto scrapyards that Comanche and Cherokee are and can be compatible with parts from one another. I have a 1989 Comanche and a 1996 Grand Cherokee; my question is would it be possible to swap the engines from one to another if both have a straight 6- 4.0L? If so, what all needs to be swapped?
stinealbert is offline
post #2 of 2 Old 12-14-2011, 12:20 AM
jeepjunkymike
same long block,,,you will have to change the intake and all the other goodies
but it will bolt up just fine ,,,mine is a 95 and ended up putting an 89 motor in mine ,,only 65k,, no probs and been 2 yrs now
jeepjunkymike is offline
1996 engine compatibility? crosschecker XJ Cherokee Technical Forum 2 01-09-2011 10:38 AM
97 Cherokee Engine Compatibility 110JBP XJ Cherokee Technical Forum 9 09-07-2010 11:38 AM
engine compatibility nhlnms XJ Cherokee Technical Forum 12 06-16-2010 01:55 PM
2.5 engine compatibility 01xjltd MJ Comanche Technical Forum 1 04-03-2010 09:01 PM
Engine compatibility Lkhoyt XJ Cherokee Technical Forum 9 06-08-2007 09:49 AM
