engine compatibility - JeepForum.com
post #1 of 13 Old 06-14-2010, 08:57 PM Thread Starter
nhlnms
i have a 1991 4.0 cherokee i was letting a family member use and they ran the jeep without oil and then continued to drive on the highway with the temp gauge at the max. the jeep still starts but runs really rough and will overheat within a few minutes. my parents have a 1998 cherokee with the same motor theyre no longer using. would their motor bolt right in with all the same electrical connections or are there gonna be some differences?
nhlnms is offline
post #2 of 13 Old 06-15-2010, 03:53 AM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
1991 is OBD-I and 1996 or 1997-2001 is OBD-II, so no, it won't just bolt in/plug in. You can use the block and head from the 98 and the fuel injection, throttle body, and other sensors from the 91.
Any running Cherokee is worth more as vehicle than as parts. Why not find an engine from the junkyard and drive or sell the 98 ?
CJ7-Tim is offline
post #3 of 13 Old 06-15-2010, 06:58 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
As Tim says, you'll have to take the 98 engine down to a long block, then swap all of your manifolds, bracketry, distributor, sensors etc over. Not a big deal and the motor is free, along with you knowing it's history.
cruiser54 is offline
post #4 of 13 Old 06-15-2010, 07:53 AM
lowicz96
1995 XJ Cherokee
I would rather have the 98 than the 91, or both and find a decent motor somewhere else
dare i say, stroke out the 91 for a trail rig and dd the 98
Project/DD - 95' Cherokee Sport, 2 Door, Converted to 4x4, AX-15, NP231, Black and lots of other goodies
88' Cherokee Limited - RIP
Sold - 96' Cherokee Sport 4x4, 2 Door, AW4, NP242, Its the girlfriends now!!
lowicz96 is offline
post #5 of 13 Old 06-15-2010, 07:59 AM
75SV1
'91 was the first year for the HO. The '91-95 are basically the same motor. In '96 the did some changes to the block and some changes to the head. The block got some stiffening ribs around the cylinders. The head is also dowel pin located. Still, they are considered HO motors. Physically, it will bolt right. Your sensors should bolt right in from your '91. The only problem that I know of is that the '91 has an extra water temp sensor on the drivers side of the head. The '98 won't have the port for this sensor.
Tom
75SV1 is offline
post #6 of 13 Old 06-15-2010, 09:00 AM Thread Starter
nhlnms
i would just drive the 98 but the body is all rusted. ive been having an over heating issue with the 91 for some reason. i replaced the water pump and thermostat but for some reason the cooland isnt being pushed through the motor. even when the engine is warmed up if i squeeze the upper radiator hose there is no fluid going through it. im unemployed and really dont have the money to put into this thing so im thinking i may just have to sell it cheap and buy a beater. this sucks
nhlnms is offline
post #7 of 13 Old 06-15-2010, 09:37 AM
75SV1
I don't know the extent of the damage to the '91 motor if any. I would suspect a warped head, if it overheated. The '98's Radiator has an aluminum core. Some say it does a better job of cooling.
Tom
75SV1 is offline
post #8 of 13 Old 06-15-2010, 12:12 PM
superj
swap your head from the 98 onto your block and use your intake, exhaust, injection, etc.
I don't feel like working on anything at this time so i sold my yj.
superj is offline
post #9 of 13 Old 06-15-2010, 12:28 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
You don't need to do this.
post #10 of 13 Old 06-15-2010, 07:02 PM
SemperFi1371
1990 XJ Cherokee
I have a question, will a head from a '91-95 bolt up on a '90? I have a 1990 4.0 and I'm working on a job that happens to be an engine core reseller but they dont carry the head from a '90 but are willing to give me any head that I want, so im wondering if it will bolt up?
SemperFi1371 is offline
post #11 of 13 Old 06-15-2010, 07:28 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Yes, it will. The intake ports are a little different but just use the gasket that matches your manifold and you'll be fine.
post #12 of 13 Old 06-15-2010, 11:14 PM
pentastar01
I'd make said family member pay for a JY motor, but that's my opinion.
Life's tough, that's why I drive a Jeep. Until it breaks, then life's a *****.
pentastar01 is offline
post #13 of 13 Old 06-16-2010, 02:55 PM
75SV1
Basically, any year Jeep 4.0L head will fit or swap onto any year Jeep 4.0L block. The latter blocks, 96+, used some location dowel in the block to locate the head. I am one of the few who had problems putting a '95 head on an '03 block. Still, I think you are asking if a '95 head and a '90 block would work for you. I woul say yes. The '90 block should bolt right into your chasis etc. The '95 head should bolt onto the block just fine. You will have to align the head onto the block by eye. The bolts will get you close. You could make some aligning sleeves, I guess. One of the bolts needs thread sealant on it. It is torques a bit less than the others. Your '91 intake etc, will match up up the '95 head.
Tom
75SV1 is offline
2.5 engine compatibility 01xjltd MJ Comanche Technical Forum 1 04-03-2010 10:01 PM
2.5l compatibility czaker MJ Comanche Technical Forum 1 03-22-2009 10:40 PM
XJ and TJ compatibility? mknherhappy XJ Cherokee Technical Forum 4 10-29-2007 05:38 PM
Engine compatibility Lkhoyt XJ Cherokee Technical Forum 9 06-08-2007 10:49 AM
compatibility? jftimbo MJ Comanche Technical Forum 7 10-06-2005 02:04 PM
